I am going to swap a '71 400 from a Grand Prix into my 69 Lemans. The motor is relatively low milage, 79K, and runs well. I bought it because I don't want to do a rebuild right now. While the motor is out of the car is there anything I should replace? I'm already figuring on doing the oil pump and timing chain. Is it possible to do the rear oil seal without removing the crank? Any input is appreciated. T
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
DO the pump/chain good plan.
put the motor on a stand you should anyways turn it and pull the pan your going to have to anyways to do the pump and replace the seals/gasket,nows a good time to paint it! newtown? huh? what color is your car? i mite of seen it. jeff --------------------------------------------------------- "...And on the seventh day God raced his GTO!" ---------------------------------------------------------
--------------------------------------------------------- "And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor?? --------------------------------------------------------- |
Limelight Green convertible. I am planning on painting/ detailing the motor and compartment while its out. What are you driving Jeff? If you go to Marcus Dairy on Saturdays it's likely you have seen it. Also goes to all the Nutmeg shows.n
It is possible to install a new BOP rear main seal without completely removing the crank in a 400. You have to remove the rear main cap, and completely loosen all the other main caps, then have a buddy help you lift the crank to get out the old seal and install the new one. You don't have to remove any rod bolts. Might as well do it if you're gonna replace the oil pump. You're almost there.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc. '02 Firebird, V6, auto '68 GTO Convertible, HO, 4spd, driver '66 LeMans Hardtop, 400, FI, A/C, 4L80E. '65 GTO Hardtop, restoration ongoing '64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue. http://www.gtoaco.com |
Jeff, did I steal your motor, or did you steal mine?... [img]/infopop/emoticons/icon_biggrin.gif[/img]
http://www.kurtspontiac.homestead.com/Dannys65GTO.html
http://www.youtube.com/watch?v=iJrDl3nRNCM http://www.youtube.com/watch?v=Fvywdocl4GA http://ultimategto.com/icongraf/65headtitle.jpg |
Jeremy- How's it going? Welcome aboard!
Tough call on the seal. I'd probably leave it alone. Do the chain and pump though. Good luck, Phil Upton http://home.earthlink.net/~uptons1/
_________________________ _________________________________ http://www.youtube.com/watch?v=_qZgOpn-w-o <<< Burnout Video ![]() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "Treat Me Good, I'll Treat You Better; Treat Me Bad, I'll Treat You Worse" Sonny Barger ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
Hey Phil, How ya doing? I've got to check the seal to see if it's already leaking. I just got the car here yesterday. Jim said he'd help with the swap, you could come up too and make a party of it.
Jer.l
I would take the opportunity to replace the cam and lifters. At 79K the cam more than likely has at least one lobe going flat. You can re-paint and re-seal the valley cover as well as the intake manifold while you do the cam. With a new timing chain, oil pump and new cam it should run like a dream. [img]/infopop/emoticons/icon_wink.gif[/img]
Let's go racing! www.outlawpontiacs.com/members/B-Man2.php www.outlawpontiacs.com/members/B-Man.php
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
BLACK 69-GTO, I Used to live in newtown,sounds like you got a nice car! while your at it a cam might be a good thing to change as well,rockers, pushrods, mild valve job.. but don,t listen to us!we are nuts and will spend all your money!!
welcome! to P.Y.!! HEY GOATHEAD!..All great motors look alike! [img]/infopop/emoticons/icon_biggrin.gif[/img] --------------------------------------------------------- "...And on the seventh day God raced his GTO!" ---------------------------------------------------------
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Hey Phil, How ya doing? I've got to check the seal to see if it's already leaking. I just got the car here yesterday. Jim said he'd help with the swap, you could come up too and make a party of it.
Jer.l <HR></BLOCKQUOTE> Sounds like fun, let me know when you're doing it. Phil http://home.earthlink.net/~uptons1/
Let's see, how much money we can spend of yours Jeremy.
- Ditto on the CAM/Lifters/chain - New Chrome Valve Covers ( good for 5 MPH ) - New motor mounts - Add RA/HO manifolds - Ditto Oil Pump - Add a posi rear w/some gears - Set of gauges for inside car - Have radiator professionally flushed - New Water pump - Paint accessories ( alternator/PS pump ) - New plug wires; distributor overhaul w/curve - Add MSD box w/rev limiter - Have driveshaft and joints rebuilt / balanced - New Converter would be major bang for buck More will come to mind, but I can live vicariously through you. You have 9 months to get that thing in shape for a rematch against me on the way to the Nutmeg POCI show at Barberino Pontiac. [img]/infopop/emoticons/icon_biggrin.gif[/img] My goal is for you to spend enough money to beat me. Then I can justify spending some money of my own. I don't even think about trying to touch Phil's car, he is in another league. - Jim Doran -Some Pics of my 65
-Jim Doran- 1965 389 Tripower; 4 speed; convertible 2019 Tesla Model 3 Performance 2016 Chevy SS; Sold 2001 Toyota Tacoma 4x4 2008 Infiniti G35x |
I know that you said that you did not want to do a rebuild now, but if the motor is out, I would replace the bearings and rings. Doing that, the crank is out and the BOP seal installation is a no brainer. I put one in my motor, and I don't think that it can be done without pulling the crank. I could be wrong, though.
[img]ftp://members.aol.com/gr8one68/gr8one68.jpg[/img]
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac |
Jim - Nice words about my car, thanks. But I never really got it running the way I'd like. I think another quick rebuild and a set of ported heads are coming this winter.
Jeremy - Jim has some good points there about what else to do with your car. http://home.earthlink.net/~uptons1/
OK you guys have sold me on the cam and lifters. I am trying to avoid getting sucked too far into the "if you're gonna replace this, you might as well replace that" situation. Still considering the rear seal, I hate having a car that marks its territory. If I replace the rear seal may change the bearings. Jim, as far as your suggestions, you'll have to hire me to work on your house to pay for all that. My next job is in New Milford anyhow! I think I can already take your goat.... on top end. Love those 2.78 gears. Great for highway cruising. I'd love to do the HO manifolds but I'm having a hard time justifying the cost for the manifolds and new head pipes especially considering how I drive it. Phil your car IS cool, now if we can just do a little with the interior.
Jer.I
Regarding the BOP seal, It can be installed properly in a 400 without removing the crank completely. I've done it.
Rons right i,ve done it to, The seal is not that bad to do. just take your time!Because new pont seals leak just as bad as old! Make sure to grease it.Me or one of us can walk you through it.
what did you choose for a cam? jeff [img]/infopop/emoticons/icon_biggrin.gif[/img] --------------------------------------------------------- "...And on the seventh day God raced his GTO!" ---------------------------------------------------------
Trying to show a picture of the patient. First time trying this, lets see if it works›
Awesome ride. [img]/infopop/emoticons/icon_cool.gif[/img]
Nice looking car goatless! So you're not really goatless after all! [img]/infopop/emoticons/icon_wink.gif[/img]
http://kurtspontiac.homestead.com/TimSimpson66GTO.html |
