I am familiar with the formula that calculates predicted RPM for given tire height. Have also calculated (predicted) converter slippage for new converter. I would like to cross the finish line between 5800 and 6000rpm. The unknown factor is adding a 250 shot of nitrous. The converter was built for the nitrous and should be very tight, shooting for 3200 on motor and 4000 to 4200 on the gas. What tire would you experienced nitrous users choose?
130 mph on motor T-400 3.73 gear Max size I can use...30" / 10.2" wide Should I wait and see what the converter does before purchasing tires in case the converter is a little too tight or loose? Thanks
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
Tallest tire possible at all times. Adjust everything else from there.
Chance favors the prepared mind. |
I'm running 28x9's right now with 3.73 gears & i have killer sixty foots but no top end. I think my tires are to short so i'm going to try 29.5 x 9.
Which brand and tire are you going to try Scott?
Thanks http://home.earthlink.net/~uptons1/ <~~some pics of my 65 GTO
_________________________ _________________________________ http://www.youtube.com/watch?v=_qZgOpn-w-o <<< Burnout Video ![]() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "Treat Me Good, I'll Treat You Better; Treat Me Bad, I'll Treat You Worse" Sonny Barger ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
i switched from 28x11.5 ET streets to 29.9x9 slicks and picked up .2 on the big end while the 60 ft. times stayed the same to within a few thousandths. i hope to be ditching the leaf spring suspension soon in search of more traction.
i couldn't be happier with the taller tire from a performance standpoint though...shifting at 6000 it goes through the traps at ~6200~ rpm weighing in at ~3800~ with a 4.11 gear. i'm not a math expert but i think the 29.5" tire turned the 4.11 into more like a 3.70 gear... 97 Trans Am WS6 Best ET: 12.13 Best MPH 114.6 74 Formula 455 Best ET: 11.83 Best MPH: 113 |
With a 130 on the motor I think you will over rev with a 28" tire. A 29.5 or 30" should be pretty close but with the n2o go with what Goatman said and put the biggest tire you can fit on there and you will probably still have to gear down.
Thanks for the advise guys...with the previous too loose converter and 28" MT's, I could not make it down the full quarter without getting on the rev-limiter at 6600rpm on 175 shot. Was'nt sure just how much the converter contributed to this. Probably go with the 29.5x10.50 MT's, but am considering running tubes in them to stiffen the sidewalls for the violent launch with stock suspension. Anyone experienced with running tubes with transbrake or manual trans cars, or just hard leaving cars in general? Still pics of car leaving show the tires squashed almost to the rim and wrinkled badly.
I agree with Goatman, put as tall a tire you can get away with. Then adjust the gear if needed.
with out questions there can be no answers 1969 Grand Prix [email protected](1.358) [email protected](1.342) WARPed Tepee Forums [email protected]
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
I'm going with Mickey Thompson slicks. Car sixty footed 1.44 with 28x9 Mickey's at Norwalk friday night. Torqjunki go with the Stiff Sidewall slicks & forget about the tubes.
Stiffer sidewalls will help. If the tire maker of your choice does not make a stiff wall tire in the size you want there are a few ways you can help yourself.
1. Run tubes in the tires 2. Run a wider rim. For instance; run a 10 inch wide slick on a 11 or 12 inch wide rim. Good Luck, Ron
![]() Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
My intention was to run a stiff sidewall slick, but I don't think the MT 29.5x10.50 is available in a stiff sidewall configuration, thus the idea to run tubes. Still thinking about some Goodyears also. Are they stiffer than the MT's?
Am told that the Goodyears will last much longer and possibly more consistant. Now that I have narrowed the search to a near 30" tall tire, I can search for the right compound and stiff sidewall. Want a med compound. Scott...1.44!!! That rocks Keeping in mind that I am running a 8 or 8.5 wheel, and that I need a stiff sidewall, would it benefit me to run a 9" wide slick? Would the better match of the rim and tire width make up for the 1" less tire on the ground? Maybe the 9" patch would all be on the ground where the 10+" would not utilize the edges due to the 8" wheel. Thoughts...Seems to be working for Scott. All that delicate work on the inner wheel well with the sledge hammer for not
NO TUBES.
Only benefit: Extra rotating wieght. Leave them out and get the 29.5x10.5W's. All you'll need. Chance favors the prepared mind. |
I would stay with the 9inch wide slick with the 8inch rim. If you go 10 inch definately go with a bigger tire.
I'm running the Phoenix 29x10.5 slicks. Not much choice but to run tubes with them, they leak air right out the sidewall
The secret to happiness is not getting what you want but rather, wanting what you have.
The secret to happiness is not getting what you want but rather, wanting what you have. |
Goatman...would love to run the stiff wall "W" tire, but like I said, max size I can run is 10.2 wide.
Torment...Are the Pheonix tires a med or hard compound and how many passes can you get from them? Used them long? Why did you choose them? Thanks
The Phoenix slick is 10.8 & F9 compound which is the Medium comp.
Dave, You can trial fit my 29.5 radials and even make a pass or two with them if you want.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Thanks for the generous offer Skip. THe car is not near ready and I plan to have slicks ready to go before it gets finished. I have a connection for the MT's and can save quite a bit of money on them. Will probably end up using the 29.6x9.0 radial. If it is not stiff enough, I will try tubes. Second choice would be 30x9 Goodyear radials. Looking like I may show up to Nats in primer
Dave, My Hoosier radials are DEFINITELY stiffer sidewalls than the M/T bias. They don't seem to be leaking any either.
I've got some Nittos and my car is finally old enough to get inspected!
