Old 11-16-2001, 11:16 PM
455Dave's Avatar
455Dave 455Dave is offline
I removed my aftermarket chrome valve covers from the 455 and the stock covers seem to be a bit short. Even though no oil drippers are installed on the factory covers, the roller rockers are hitting the lower edge of the covers slightly.
Two questions:
Since this is an AC car, the air conditioning to intake braket is pretty close to the passenger side valve cover. Does anyone make a thicker gasket that will cure this problem?
If not, any recommendations on tall covers that look a bit stock? If I use tall covers, I'll cut the AC bracket and modify it to fit. I'd rather use stock height valve covers, but the tick is driving me nuts.
Dave
455Dave's Avatar
Two questions:
Dave
Old 11-16-2001, 11:28 PM
Use 2 valvecover gaskets per valvecover.
or
Spotty has the extra thick gaskets for this situation.
Old 11-16-2001, 11:30 PM
455Dave's Avatar
If I use two gaskets, should I use some RTV between the two or will they seal up without?
Dave
Old 11-19-2001, 10:02 PM
Redlined455HO's Avatar
Redlined455HO Redlined455HO is offline
Dave
Use Felpro part # 1627 - thick cork gaskets, had to use them to clear my roller rockers.
Barry
66 Corvair Corsa - not so stock
74 Formula 400/4 sp - stock
79 TATA - almost stock
78 TA - owned it since new - not so stock (11.28 at 118.6)
Old 11-20-2001, 12:08 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Same here. I ordered mine from Nunzi which were $26/pr. No more clearance problems. You may find you need a bit longer bolt for the valve covers.
Old 11-20-2001, 12:30 AM
Gooatee's Avatar
Gooatee Gooatee is offline
Not sure how much clearence you need but, the Felpro #FPP-1627 is 1/4" thick as stated above and they are only @ $18.00 in Summit and Jegs!
