Old 11-03-2004, 11:45 PM
RAJNWDY's Avatar
RAJNWDY RAJNWDY is offline
I hope these pictures help many of you who are trying to rid yourself of a slim Jim...
RDRR Custom Fabrications
....A fictitious company doing fictitious work....
RAJNWDY's Avatar
Old 11-03-2004, 11:49 PM
RAJNWDY's Avatar
Sorry about the size of the pictures but I'm sure you won't need a magnifier to get the Idea of what I did. Only problem is that I have to still shorten the drive line about 3/4's of an inch but the car drive's wonderful....
set of pictures # 2
Old 11-03-2004, 11:58 PM
RAJNWDY's Avatar
here is the last set of pictures, and for all of you guys that are thinking of doing this. Do it and you won't be sorry, just remember that the 63 engines will not have bolt holes for the starter so if you can find a newer 389, or go with something else as I did (455) You will have a blast once you drive it!!
Pictures set #3
Old 11-04-2004, 12:06 AM
RAJNWDY's Avatar
here is a final shot of the car from inside...
Old 11-04-2004, 08:05 AM
Deadhead's Avatar
Deadhead Deadhead is offline
EMD,
Thanks for the info! Did you use a shorttail on the wagon? It is a shorter wheelB than sedans.
Also, you can use a crossmember from a pre- '75 Caprice that is flipped & bolted to the bottom of the frame to allow for duals & speedo cable clearance. It has 2 humps that are perfect for this & allows for regular mount - for those of us w/o a welder.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
Old 12-06-2004, 10:26 PM
gregneun gregneun is offline
I've been "lurking" on this page for quite a while, I finally registered. I'm putting together a 64 GP. Any tranny help will be appreciated. I'm not even sure how bad my slim Jim is, as the car sat for 8 years. I know I didn't put the breather back in when I re-assembled the engine/tranny. I found it in the shed.
Old 12-14-2004, 09:10 AM
Engine-Ear's Avatar
EMD~
warm thanks for sharing your experience with us!
My '62 Wagon is getting a TH400 and it's helpful to see how someone else did it.
Old 12-16-2004, 12:22 AM
RAJNWDY's Avatar
Glad to help out any way I can!
Old 12-20-2004, 04:11 AM
Scott Misus Scott Misus is offline
I've also seen the flat 65-66 full size crossmembers used, as they have kickups for the exhaust, and are wider.
Old 12-20-2004, 11:10 AM
engineer engineer is offline
forget that, how did you hang the starter on a 63 since the block has no mounts?
Old 12-20-2004, 01:50 PM
Deadhead's Avatar
I think he's got a 455 in there, so he solved the starter problem the easy way.
-LBJ
66 Bonneville wagon
Old 12-20-2004, 09:48 PM
RAJNWDY's Avatar
YEP! if you look at the third set of pictures in the header, I explain that and more!
Thanks for the replies.
Old 12-21-2004, 11:02 AM
so the age old question remains for the purist.
Old 12-22-2004, 01:36 PM
Deadhead's Avatar
Engineer- Indeed. Still doomed. I am going to have a Superhydramatic rebuilt & am prepping a '66 389 & TH400 at the same time as I can still not decide. In my gut I think the Super is the way to go, but the common nature & dependability of the other combo is hard to pass up.
-LBJ
66 Bonneville wagon
Old 12-23-2004, 02:47 AM
RAJNWDY's Avatar
Yes you could be a purest and keep the 389 which is a fantastic engine, but of course with the starter mounting problems, then you have to realize that some changes need to be made. The Roto is obviously not everybody's favorite, the Hydramatic is getting hard to find and then there are far far better up grades that can be made and still keep your car "LOOKING" stock. Of the easily seen items in the picture that follows, you would be hard pressed to guess that it wasn't a stock engine if you didn't know what to look for. 6 things in this picture will tell you that it's modified but is it a 389 or a 400, or one of the big crank jewels? Valve covers, HEI, Headers, Edelbrock manifold, 8 bolt water pump, Yes these could be put on the 389 and with the proper Paint for the year, who would know other then a Pontiac guy that would know that 66 heads came on a 455, and the transfer lug would tell you it is something other then the 389-400 block. Yes you can be a purest, or you can be the hot rodder, that is what is neat about our hobby. Build it the way you want, drive it the way you want, and get more satisfaction then 2 weeks after you sign your wedding license!!
Old 01-29-2005, 09:50 PM
RAJNWDY's Avatar
Just bringing this to the first page...There are more questions about this install and this might help....
Old 01-31-2005, 03:38 PM
JDOROUR JDOROUR is offline
Nice.
I have used the cross member from late 70s and early 80s B and C body cars as well. You have to look hard to find one out of a Buick, Olds or Caddy diesel that will have the double hump for dual exhaust.
1966 Catalina 2 Seat Wagon,White over Red, 421HO (WJ Code), M21, 4.11:1 Posi, PW, PSeat, 8 Bolt Wheels, AirCond.
Old 01-31-2005, 04:16 PM
CARNUT CARNUT is offline
WHAT DID YOU ABOUT THE STARTER
Donald R Rice
Old 01-31-2005, 05:58 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by CARNUT:
WHAT DID YOU ABOUT THE STARTER <HR></BLOCKQUOTE>
He said he is putting a 455 in the car.
