Old 03-19-2005, 06:45 PM
canuck383 canuck383 is offline
I am putting together my front bumper assembly complete and running into issues. Any pointers will help me immensly.
The car was in an accident and I bought OER parts from Classic. The LH or drivers fender has a bump up in the middle of where the park light installs. The RH doesn't. This doesn't belong there.The valance panel on the LH or drivers side has the hole pattern off by over half an inch.
I paid a body shop to assemble everything last year but nothing lined up when I got the car back. They told me the guy doing the work quit and I needed to take my car. Being a dumbass I never hammered on them then.
I took it apart 2 weeks ago to find brackets that were bent though they said they straightened them.Loose bolts, missing bolts and bolts in backwards etc. Then the problems with OEr'S/Classic's parts.Anyway after drilling and realigning things and straightening the brackets that mount to the frame I had all but the bumper and grilles and light buckets on the car.This is where I am stuck.
I am now looking at it as if I need to assemble the whole thing separate from the car then attach the frame brackets and top corner bumpers last.Is this right?Please help.
Old 03-19-2005, 06:49 PM
This is a 68 firebird coupe.
Old 03-19-2005, 08:21 PM
Hammered's Avatar
Hammered Hammered is offline
The bumper attaches as an assembly with the frame brackets and headlight buckets attached. It bolts to the frame and ties to the core support brackets through two rubber isolators. The headlight buckets have one screw that attaches to the core support. I would leave all the fasteners a little loose until you get in place then selectively tighten them.
It sounds like your LH fender may be for a Camaro. Those cars had a recess for a bumper bracket that was sandwhiched between the fender and fender extension in the same location that the FB parking light goes on a '68.
John
1967 Firebird Convertible Factory 400/4spd
Now 462/5spd Fuel Injected
http://1967firebird.atwebpages.com/
Old 03-19-2005, 10:45 PM
And being I bought it over a year ago and it has been used I bet Classic won't do anything for me. I can't believe the body shop didn't say anything either. My luck. Thanks for your help.
Old 03-21-2005, 10:30 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Would a blow up diagram of the front end help you any ??? I have a bunch of PDF files that have the blow up parts manual diagrams. If these will help drop me an email.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
