Old 02-06-2003, 05:59 PM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
Do any of you have a spare ring for the D.S.highbeam? for a 69-GTO found out that they are not all the same, and can,t find one anywhere! (dealer, yearone, ect) thanks for any help in this matter!
jeff
"...And on the seventh day God raced his GTO!"
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
JEFF KING's Avatar
jeff
Old 02-06-2003, 06:11 PM
goatless's Avatar
goatless goatless is offline
Jeff, I think I have one. I'll have to dig around.
Jeremy
1966 GTO
Old 02-07-2003, 05:20 PM
JEFF KING's Avatar
THANKS! GOATLESS let me know.
jeff
Old 02-08-2003, 02:04 PM
goatless's Avatar
Sorry Jeff, I came up shy. Only one I could find had a popped seam. They shouldn't be that hard to though. I'm pretty sure they interchange between all the '60s four light setups. Good luck.
Jeremy
1966 GTO
Old 02-08-2003, 07:40 PM
JEFF KING's Avatar
THANKS ANYWAYS! goatless lets meet up at marcus some time this summer!
jeff
Old 02-09-2003, 11:45 AM
bukey's Avatar
bukey bukey is offline
I HAVE A SET YOU CAN HAVE THEYRE FOR A 68 ARE THEY THE SAME?
64 Gto
65 Gto
68 Gto
64 Corvette
67 SS 396 camaro
76 BMW 2002
05 Silverado 3500
09 G8 GT
Old 02-10-2003, 12:08 PM
JEFF KING's Avatar
I only need one ds high beam, you have to match it up to tell. but i,ll take the set if you don,i mind
BUKEY, e-mail me with details [email protected]
thanks for the help!
jeff
Old 02-10-2003, 07:19 PM
bukey's Avatar
sent you mail
64 Gto
65 Gto
68 Gto
64 Corvette
67 SS 396 camaro
76 BMW 2002
05 Silverado 3500
09 G8 GT
Old 02-22-2007, 07:48 PM
bukey's Avatar
Originally Posted by bukey
sent you mail
mmmkk
Old 02-22-2007, 08:36 PM
engineer engineer is offline
popped seam can be fixed and NO all the rings are not the same. Early ones up to about 68 had hole in ring for spring to hold in place of one screw.
Old 02-23-2007, 12:03 AM
gto4evr gto4evr is offline
Not correct of course, but I came across a neat trick someone did with a car I'd parted: the retaining rings are different but usually have 2 of the three holes lined up. The previous owner had bent the non-aligned tab back around itself so it hooked around the edge of the headlight cup then mounted the other two screws. It held the headlight just fine.
