Old 04-11-2003, 08:10 PM
Hawk397 Hawk397 is offline
Send a message via AIM to Hawk397
Finished up the tune on my car today and was getting ready to install a new set of wires. (These are correct reproduction date coded noise suppression wires) Just for the heck of it, I ohm'd out the old wires - around 1K ohm each. Then I checked the new ones - around 14K ohm each!!! WTF?
I'm running the stock points system. What should I look for regarding resistance? (The wires on my Hawk are around 150 ohms!?)
Thanks!
Mark T
1974 White Super Duty Trans Am
1999 Red TA FireHawk #397
2002 Best: 11.68@116 NA (10.7@127 on the Juice!)
71 Firebird Custom - Fuel Injected & Over-drived!
Thanks!
Mark T
Old 04-13-2003, 08:48 AM
mmm mmm is offline
It made me curious so I looked around. It sounds like one of those things that varies depending on factory specs.
Resistance could be added to reduce radio interference on some wires.
Here's some of what I found:
http://www.tpub.com/basae/44.htm
http://www.inct.net/~autotips/plugwire.htm
http://www.babcox.com/editorial/ic/ic120214.htm
-Mike
I'm right at home in a filthy garage
Old 04-13-2003, 02:47 PM
Thanks for the info, Mike!
Mark
