Old 09-17-2002, 01:10 AM
takid455 takid455 is offline
Send a message via AIM to takid455
the engine CID tag is not where older pont. engines have it on your 78. it is toward the front of the block on the side. looks like an oval with 400 cast on it. its is rotated to face north - south. the 6x-8 heads are from a low compresion 400. they are not the w72 heads which are 6x-4. i just rebuild a w72 motor and this is how all teh info appeared on mine. i believe the blocks are the same.
1972 HO Trans Am auto White/white
1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue
1978 Trans am gold/ black ,T56, t tops, EFI 474,
Build: http://www.pro-touring.com/showthrea...1978+g+machine
1999 30th Trans Am 6 spd, T top
