Finished up the tune on my car today and was getting ready to install a new set of wires. (These are correct reproduction date coded noise suppression wires) Just for the heck of it, I ohm'd out the old wires - around 1K ohm each. Then I checked the new ones - around 14K ohm each!!! WTF?
I'm running the stock points system. What should I look for regarding resistance? (The wires on my Hawk are around 150 ohms!?) Thanks! Mark T 1974 White Super Duty Trans Am ----------------------------- 1999 Red TA FireHawk #397 2002 Best: 11.68@116 NA (10.7@127 on the Juice!)
71 Firebird Custom - Fuel Injected & Over-drived! |
It made me curious so I looked around. It sounds like one of those things that varies depending on factory specs.
Resistance could be added to reduce radio interference on some wires. Here's some of what I found: http://www.tpub.com/basae/44.htm http://www.inct.net/~autotips/plugwire.htm http://www.babcox.com/editorial/ic/ic120214.htm -Mike I'm right at home in a filthy garage
I'm right at home in a filthy garage |
Thanks for the info, Mike!
Mark 1974 White Super Duty Trans Am ----------------------------- 1999 Red TA FireHawk #397 2002 Best: 11.68@116 NA (10.7@127 on the Juice!)
