Old 03-27-2005, 10:17 AM
SupergasDil's Avatar
Are any of you running headers on your 61's? What kind and what year?
Someone said the early firebird headers would fit.
Old 03-28-2005, 11:45 AM
rompn63's Avatar
rompn63 rompn63 is offline
I put a set of 67 Firebird Hooker headers on my 63 Catalina and a friends 61 Ventura. I had to modify # 5 pipe to clear the steering box. It's been about 15 years since I did it. I'm pretty sure that I had to use a Super Duty upside down starter. If you are running a later block you could use a mini starter. Why dont you get a set fron Nunzi or Dick Duclow?
Old 04-04-2005, 01:47 PM
Rompn,
Did you modify with a hammer or was it some cut and weld stuff.
I'm on a tight budget for the entire car so I'm working to get as much done as I can for now. So If I can get an inexpensive set of headers to work, that's what I would like to do. I have more time than $$$
Old 04-04-2005, 06:20 PM
rompn63's Avatar
As I recall I cut a section out and rotated it 180 degrees and welded it back in. I was in the same boat as you, more time than money. It took me over five years to finish my car and I loved every minute of it. It was like having sex, enjoy it as long as you can and don't be in a hurry to end it.
Old 04-26-2005, 12:51 AM
Lil SCAPEGOAT Lil SCAPEGOAT is offline
Hey Supergus:
I probably have a Set of FireBrd Hedders
You can "Try for Fit"
When are gonna uproot the deadwood?
Are ya Gonna Trial-Fit a late model Longblock before yaSpend $$$ on a Build ? ?
KOOL
MidSize & Large Chassis are Best
Old 04-26-2005, 08:59 AM
J Brady's Avatar
J Brady J Brady is offline
Just put a set of Mad dog round port headers on my 61 about three weeks ago. Very nice and they were easy to install. You can get them direct or you can order them from Nunzi.
Old 04-27-2005, 12:34 PM
bmpmdf bmpmdf is offline
The currently made Firebird headers that I have tried had the #1 tube tring to go thru the crossmember on my 63! Then #5 had to be rotated as mentioned. I'd try the Mad dog's mentioned before I try Firebird headers again.
Have A Great Day
Old 04-27-2005, 01:03 PM
Dick Duclow Dick Duclow is offline
Indian Adventures, 40061 for Dports and 40062 for Round ports. Must have a block mounted starter
Old 04-27-2005, 08:53 PM
Dick, how does anyone get hold of you nowadays? Or you still doing the business? Thanks !
Have A Great Day
Old 05-24-2005, 01:43 PM
axle axle is offline
dil, if you go with firebird headers and they need some cut and re welding just let me know....i'll give you a hand!
