Old 02-23-2005, 07:09 AM
Rugratman's Avatar
Rugratman Rugratman is offline
I just finished changing out my old steering box, for a new quick ratio box.
I disconnected the hoses from the pump where they go into the box, and had them up high so they would not drain. I swaped out the box, which came full of fluid from the manufacturer, I reconnected the lines and topped off the fluid.
With the front end off the ground, I started up the car and turned the wheel, left and right, all the way.
I am now getting a grinding noise from the pump(?), and the fluid inside the reservoir is all foamy. Do you think this is normal and will stop once the fluid circulated around?
Something wrong?
........I'm just learning as I go.......
Rugratman's Avatar
Something wrong?
Old 02-23-2005, 10:01 AM
george kujanski's Avatar
I think that's what you will see until the air is purged out of the system.
George
Old 02-23-2005, 10:26 AM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
im no steering expert, but from what ive read the QR boxes should have, if not require, the pump pressure valve doobie be modified or replaced.
if its not an air purge situation, it might be a pump working too hard.
steering system experts?? anyone??
costs too much
Old 02-23-2005, 10:36 AM
Droptop64 Droptop64 is offline
On Vacation
Ten to one it's only the air being purged. I had the same thing happen when i replaced the box on a truck of mine. It took about 30 minutes of run time for it to quiet down all the way.
Old 02-23-2005, 10:45 AM
Rugratman's Avatar
Doobie?
Old 02-23-2005, 11:18 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by rugratman:
Doobie? </div></BLOCKQUOTE>
the pressure relief and/or flow control valve in the pump.
everything ive read indicates that should be updated to match the needs of the box. global west sells one, 30 or 40 bucks i think.
again, w/o knowing the intricacies of power steering, i would guess a "hi-po" box needs more pressure to operate effectively. if you use a "low-po" pump it will have to work that much harder, thus impacting its durability and life span.
costs too much
