Old 03-27-2005, 10:32 AM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
For those that only occasionally read this section, I’m the fool that forgot to put in my oil pump drive shaft, then tired to put it in from the distributor hole and ended up dropping it in the oil pan. So any help you can give needs to be very simple. My 455 will not start (this is the first start up after a rebuild), I’m using an HEI distributor and I think I have the motor on TDC. I have one of those cool tools that is installed in place of the spark plug; as the motor is rotated the piston forces out a brass rod. I rotate the engine until the rod stops coming out (I hope that is TDC) and then install the distributor so the rotor is pointed at cylinder 1 on the cap. Still no luck, I am getting a spark and also occasionally get a (or what appears to sound) backfire. I smell fuel so I figure that system is good as well. Any help would be greatly appreciated.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
1964 GTO Auto
Old 03-27-2005, 10:54 AM
J_JAMNIK J_JAMNIK is offline
Check compression with a tester. It is possible that you have no compression due to the valves not completely closing. If compression is very low, back the rocker arms off about 3-4 complete turns. Also check to make sure you have ignition spark.
Junk is something you've kept for years and throw away three weeks before you need it!
Old 03-27-2005, 11:04 AM
Valves aren't closing, therefore no compression. I assume hyd. lifters?
Old 03-27-2005, 11:08 AM
johnta1 johnta1 is online now
Check the usual, such as firing order.
1-8-4-3-6-5-7-2 going counter-clockwise on the cap.
#1 cylinder is driver front. 1-3-5-7
#2 is passenger side front. 2-4-6-8
Old 03-27-2005, 11:09 AM
Billy177's Avatar
Billy177 Billy177 is offline
sounds like your valves are staying open. but did you set it at tdc on the compression stroke
70 GTO
462 E-Heads TKO-600 9-Inch/3.60's
Old 03-27-2005, 12:36 PM
67cruiser 67cruiser is offline
Don,t forget also dis. turns counterclockwise!!
Old 03-27-2005, 12:39 PM
David Jones's Avatar
Take the driver side valve cover off. Remove all of the plugs. Rotate the engine by hand using a 15/16 socket on the balancer. Watch the timing mark on the balancer. Somewhere around lining up 0 on the timing tab and the timing mark on the balancer, you should find that both rockers on the #1 cylinder are kinda loose. This should be TDC on #1.
Old 03-27-2005, 02:18 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Another little tip. #3 intake valve will be open when #1 is at TDC. -Jim
Old 03-27-2005, 02:41 PM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
All good advise. But who set the valves Are they all set to 20 ft lbs like stock?
What rockers/nuts are you using the stock ones?
Well if you deck the block and take down the heads during a rebuild you must set/lash the valves.
They may be too tight try loosening the rockers.
I,ve seen this before.
Best of Luck!
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
Old 03-27-2005, 02:53 PM
Dragncar Dragncar is offline
When you are building your Pontiac engine and lining up the timing marks on the timing gears as shown in the engine manual, at that point the motor is accualy "up" on number 6.You can either install the distibutor with the rotor pointed at number 6,which works fine.Or just turn the motor over exactly one turn and install the distributor with the rotor pointed at number 1.
Old 03-27-2005, 04:12 PM
I picked up a compression tester today, but my wife will beat me if I spend too much of Easter under a hood. If it turns out that I have over tightened the rockers (by the all stock), what is the best proceedure for valve adjustment. I thought I followed the instructions, but I have been known to over tighten most things anyway.
1964 GTO Auto
Old 03-29-2005, 04:27 AM
buwalda buwalda is offline
The piston reaches TDC TWICE. On the compression stroke & on the exhaust stroke. You have to make sure you have the dist is firing on #1, on the compression stroke. The surest way to determine this is to remove the left valve cover. Rotate the engine in the normal direction [ CW ] & watch the rockers of #1 cyl. When the #1 intake closes, the piston is rising to TDC on the comopression stroke & the dist rotor should be pointing at #1.
Old 03-29-2005, 05:16 AM
cujo cujo is offline
Terry, Like Jeff said earlier, if you had the block decked and the heads milled during the rebuild process you can no longer use the stock method of setting your valve lash. You would need to buy some poly locks (I used Crane Cool Nuts) to replace your stock rocker nuts and then adjust your valve lash with each lifter on the base circle of cam to zero lash + a half turn.
Old 03-30-2005, 01:51 PM
tremo's Avatar
tremo tremo is offline
If the block was not decked and heads milled, the stock torque setting for the rockers is only 20lbs. Get a torque wrench and see where they're at. If the block was decked, etc. then check out this excellent procedure for adjusting the rockers: Pontiac Rocker Arm Adjustment
Good luck and let us know how it goes...
Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor
* Engine alive and kickin' March 2nd, '06
* RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers
* QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi
* Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+'
