Old 07-18-2000, 11:38 PM
Dave Kovar Dave Kovar is offline
I have a 455 and 3:73 rear end. I had a 4 speed in the car and blew the clutch out. Come to find out I need a 11 inch clutch to handle the torque of the 455. This means buying a new flywheel and pressure plate and clutch. I am told the Muncie will not hold up the 455. Sounds like a good time to put the original parts on the shelf and change to an automatic trans. Any suggestions on good combinations. It will go into a 70 TA.
Do I need a different trans. mount? What type of torque converter? Is a trans brake better than line lock. Who makes a good trans. What about the 4 speed trans (auto).
Are there any good five speeds (man) that will hold up.
All of your experience will be very helpful.
Dave
Dave
Dave
Dave
Old 07-19-2000, 08:36 AM
richmond gear has a tough 5-spd out ,good choice of ratios also. i heard they were going to produce a 6-spd ,anyone heard anything on that? mike
former." --Albert Einstein
- Winston Churchill
Old 07-19-2000, 10:01 AM
Scott Misus Scott Misus is offline
The six speed has been out for years. With a Long shifter, you're talking about $3200. Stick with the Nash 5 speed for cost. I see them frequently, with Hurst shifters, for about $1000.
For your '70, stay away from the slushboxes.
