Old 07-17-2001, 10:24 PM
Jon Dailey Jon Dailey is offline
I built a Pontiac 400. It has around 60 lbs of oil pressure at idle until it warms up. The pressure drops to around 25 lbs when at idle when warm. The engine has good oil pressure at about 2000 rpm, around 80 lbs. Never runs over 180 degrees. Idles at 750 RPM, Melling high pressure pump, Castrol Syntec Blend 10W-40, and yes, I did put the gasket between the pump and the block. Is this normal? What could be the cause?
Old 07-17-2001, 11:09 PM
Gooatee's Avatar
Gooatee Gooatee is offline
As far as I can tell it is normal for the conditions you describe! I have built several 400's and experienced the same results! I have one in my GTO now that is running almost the same exact way!
Old 07-17-2001, 11:10 PM
Torment's Avatar
Torment Torment is offline
Sounds normal to me john. As long as it comes up with the rpm as you noted it's fine. If you want more a idle run thicker oil.
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 07-18-2001, 12:11 AM
Engine-Ear's Avatar
Jon,
10 lbs of pressure per 1000 rpm is fine.
Therefore 25 psi / 750 rpm = 33.3 psi per 1000 rpm.
Matt in Milwaukee
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 07-18-2001, 09:25 AM
Thanks, guys! That makes me feel a lot more secure about my engine.
