Old 04-07-2005, 03:08 PM
Shadowjack Shadowjack is offline
Yeah, Bob, I eventually saw that a day or two after I posted. Fast fingers, slow eyes.
Old 04-07-2005, 04:23 PM
You think your eyes are slow you should see my typing. When I took my car on the highway for the first time after installing the overdrive I couldn't believe the mileage difference. I wish I changed to overdrive 10 years ago.
Old 04-07-2005, 04:44 PM
goathead68's Avatar
goathead68 goathead68 is offline
I have a 3.23 gear, continental 2200 stall converter, Turbo 400 transed '68 GTO. I get 10 mpg in town, 15 on the highway.
The best way to get better mileage than you're getting now is pretty basic. Fresh tune; light right foot.
Get the distributor checked to make sure the mechanical and vacuum advance are in good working order. The electronic conversion is a good way to go; less tune ups and more reliability. I've used the Mallory Unilite conversion with good success. You can gain a bit by bumping the initial timing up two or three degrees.
Old 04-07-2005, 07:21 PM
71 T/A 71 T/A is offline
I have a Pertronix unit in the stock distributor. I'm happy how the car performs with it and how well the engine starts quickly in the morning. I have the distributor advance hooked up to ported vacuum in the front of the carb.
A new 200r4 would cost a lot and would be tough to justify with a T400 that was rebuilt 1000 miles ago. Is the Holeshot 2000 12" converter costing me gas mileage. Would a change to a lower than stock stall converter be a worthwhile investment?
Old 04-14-2005, 08:41 PM
69Goatfarmer 69Goatfarmer is offline
Come on:
G - Gas
T - Tires
O - Oil
They use it up.
66 GTO Hardtop 428 Auto
69 GTO Conv. 400/4sp
75 Honda CB550
04 Grand Prix GTP Comp G
Old 04-15-2005, 06:27 AM
rknrl69 rknrl69 is offline
HAVE YOU CHECKED YOU GAS TANK FOR A SMALL LEAK. MY 2+2 GOT 10MPG. I WAS AT A STOP LIGHT AND A MOTORIST BEHIND ME SAID EVERYTIME I WOULD TAKE OFF FUEL WOULD SPILL OUT. SMALL CRACK IN FILLER TUBE. MADE REPAIR AND GOT 15MPG IN CITY. WITH 421 HO 3SP MANUAL.
Old 04-15-2005, 07:34 AM
Gas tank is new. There are no fuel leaks. 3.55 gears need to go.
Old 04-15-2005, 11:33 AM
68bird400HO's Avatar
Before you lose the 3.55 gears, make sure your carb is properly tuned to operate as efficiently as possible. Also, look into recurving your distributor. I have mine set up for 22 degrees mechanical in the distributor all in by 2,800. I also went to the adjustable vacuum. "Suntuned" on the classical pontiac board set up my distributor. Cliff R. is real good with quadrajets. Making sure these are dialed in can enhance performance and mileage.
Old 04-18-2005, 04:56 PM
If you still have the stock convertor it will help around town but at highway speeds the other convertor will be above the stall speed anyway.
Old 04-19-2005, 04:39 AM
kaysersuzuki's Avatar
kaysersuzuki kaysersuzuki is offline
if you have to worry about gas milage in a gto ,then maybe it should be parked,no my gtos are not all built up,my convert is stock exept for the ram IV cam and a hollybut i get between 6-8 which aint all that bad considering i drive it the way it was ment to be driven,now if you want to look cool in your gto and get good mileage i would suggest parking it on the frt lawn and just sitting in it lol
home of the never ending list of pontiacs
2 69 gto converts
1 69 gto htp auto trans
1 69 gto 4 speed
1 69 gto judge
1 75 ta
1 79 formula
1 80 formula
1 81 ta
1 89 formula
1 96 ta
1 66 mustang
1 84 mustang
1 89 25th anniv mustang convert
[email protected]
Old 04-19-2005, 04:40 AM
and i really dont measure the gas milage i measure how much fun i get out of a tank
2 69 gto converts
1 69 gto 4 speed
1 69 gto judge
1 75 ta
1 79 formula
1 80 formula
1 81 ta
1 89 formula
1 96 ta
1 66 mustang
1 84 mustang
[email protected]
