Hello friends. I'm wanting to change my breaks on my 68 Firebird from power drum to disc. I was told I needed parts from 68-74 F body. Or, from a 68-74 Nova. My question is, are there any other cars thta will convert over to my Firebird ??
Also, (and this is a must) I want to swap my steering box to a faster ratio. What cars and box would I need to bolt into my Firebird ? Thank you all, for any information you may have. I've learned alot from asking questions here. And the one thing I learned was to not worry about making a mistake. I just go back and work it out until it's right. ONce that has failed I pay big money to some person who does know. Knows how to "keep trying" until they get it right. [img]/infopop/emoticons/icon_smile.gif[/img]~ Mike ------------------ "Michael" It's more than just a name. It's a way of life
Build it fast, build it right, hold On TIGHT !!! |
Moving to "67-69 Firebird and Trans Am TECH"....
You can also use 67-72 A body disc brakes on the early Firebirds all you have to do is unbolt the steering arms from drum brakes and bolt them to the disc brake spindles
Doesn't the 69-74 Nova also fit as well? I went through this with my 69 Bird. At the end, I decided to buy a new complete upgrade from Master Power Brakes. This was 7 years ago. I think I paid $798.00. I'm sure it's up to or over $1,000 now. The only good part about buying the conversion was that everything was brand new. I even got a set of brand new Carbon metallic pads and Bendix brand shoes for the back.
------------------ <BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Life is what happens to you while your busy making other plans. --John Lennon<HR></BLOCKQUOTE> www.69BirdOfFire.com [This message has been edited by MitchGM (edited 04-09-2001).]
"Life is what happens to you while you're busy making other plans." "More tears are shed from answered prayers, than unanswered prayers" |
O.K. fellas . . . I could use a little clarification on this subject as I'm in the same boat as Mike on this deal on a 68 Bird. I have already mounted my disc brake set-up that came from an A body donor. Ken mentioned a critical point, you MUST use your drum brake steering arms if you go this route. I thought I was going crazy because the arms that came with my disc brake set-up would not allow the outer tie rod ends/arm/spindle to be assembled properly. Then just for kicks I tried my old drum arms and everything came together perfectly.
Now for my questions which I'm sure will benifit Mike: > Will I have to weld brackets to my sub frame that will support my new brake hoses? > I am told that I will have to add a front/rear brake proportioning valve, is this true? |
YEAH, WHAT HE SAID !!! Same question goes for me too Lololo
Disc Brake hose brackets...Rick's 1st Generation Camaro sells the 3 brackets needed to mount the 69 style brake hoses if you want to duplicate a '69 disc set-up to the T. They also sell the '67-68 4 piston brake style hose brackets for those going back with 4 piston brakes, but who have no hose brackets. Do not think Performance Years sell these brackets otherwise they would get the nod [img]/infopop/emoticons/icon_wink.gif[/img]
Proportioning valves & lines...Major nightmare to unravel here in print w/o detailed pics. Needless to say, it all boils down to how much you want to spend & how clean a job you want! 1st off the original resto look. Problem.. original 67-69 F-body metering valves are tough to find, but can be rebuilt. These valves are out there but are not cheap, rebuilt. Will also need the repro line set-up for a '69 F-body, if you are going to go '69 disc & the repro disc hose brackets & 69 F-body disc hoses. IF you don't want to go this route, James at Inline Tube sells a conversion line set-up which utilizes a '71+ style (integral) proportioning valve & a little stamped steel bracket, which positions the proportioning valve inline under the mastercylinder. This looks real clean when installed. All the lines to make this work are there, including a line going back to the rear brake hose. I believe Inline Tubes conversion kit allows you to use the original drum brake hose brackets when touched up with a Dremel tool & you have to use the 69-71 A-body disc brake hoses as well. Hope this was of some help, I routinely put these complete disc brake swap kits together using a mix of select used & new parts. [This message has been edited by 'ol Pinion head (edited 04-17-2001).]
Thanks for the info! I've printed and filed your info. My 68 project is temporarily on hold as I'm trying to get my 75 T/A ready for O.C. 2001.
I know they might be pricey to some of you guys, but I just wanted to show them. www.mpbrakes.com I bought the whole conversion kit, so I didn't run into any problems. Master Power sells the proportioning valve. I think they start at $99. For me is was piece of mind to get the correct valve because I didn't want to hassle with the brakes, especially when we NEED them. I can report that their proportioning valve works great. No lockups. No rear or front brakes applying before the other. It worked out well for me.
[This message has been edited by MitchGM (edited 04-22-2001).]
