Old 04-12-2005, 07:09 AM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
assembling my int. finally got around to putting inner latch on. door works fine from outside of car. but sit inside and takes 3 or more pulls before door will unlatch. what or where shall I begin to trouble shoot glitch? I have lubed entire mechinism and striker. thanks in advance 4/6
70 GTO 400/[email protected]
4SLASH6's Avatar
Old 04-12-2005, 08:06 AM
PB's Avatar
PB PB is offline
Slash,
Your problem lies in the door latch release mechanism. The latch gets "wallered" out over time. They are left and right, so make sure you get a driver side mechanism, not a passenger side. These items often go overlooked. If you can find a 4 door car, get the rear ones, as they tend not be be used as much. Put those in and it should "pop" open like new.
Here is a pic of what I am talking about:
Pat Brown
Old 04-12-2005, 08:32 AM
4SLASH6's Avatar
thanks PB, I will tear into this today, cool: okay ,I see the problem, the "wabble" is from ware of either the latch shaft or bore. there is not too much play in mine though. I think when I installed the window mechinism I must of bent the pull rod. there is about a 1/4 inch of pull before the rod begins to move...I am going to try & take this slack up with a little bending of the rod. thanks again PB.
Old 04-12-2005, 09:58 AM
PB's Avatar
PB PB is offline
No problem slash, had this problem many moons ago. Bending the rod will help a bit and get more life out of your current ones. If you put ones in where the centers are good, you will see a HUGE improvement.
Pat Brown
Old 04-12-2005, 11:16 AM
Jack Peters's Avatar
Haven't heard "wallered out" in years. It is an accurate description and fix.
JLP
Old 04-12-2005, 11:27 AM
4SLASH6's Avatar
YEAH THATS A GOOD ONE JACK,...how bout "welp" I seen someone begin a sentence with that, love that word, just cant find it in the dictionary. PB I ended up bending the latch throw forward 1/4 inch or so, thus eating up the initial slack. door works as new
