Old 05-12-2000, 01:45 AM
Rocco Testa's Avatar
Rocco Testa Rocco Testa is offline
Two 80 turbo pace cars
One 81 turbo Daytona pace
64 GTO tri power auto
65 gto 4 speed tri power
70 gto Judge RA III auto
Old 05-12-2000, 11:43 AM
tonyk tonyk is offline
1970 RAIV TA, Lucerne blue, deluxe int,Automatic, low options, strictly business.
.030 over balanced, 4w disks from 79 TA
Old 05-12-2000, 07:32 PM
All4Fun All4Fun is offline
1980 Trans Am T-Top(Fisher)
Saved this one from junkyard. Co-worker caught it on fire trying to jump-start it. Fire Department put the fire out I bought it for 500.00 and and now i am trying to build a fire in it again! Out came the 301 and I am currently building a modified 400 in its place.
Old 05-15-2000, 03:19 PM
Nick Sorgio Nick Sorgio is offline
1980 Special Edition. Currently 301 soon to be 400/TH350 with rear disk setup and 15x8 snowflakes.
Old 06-19-2000, 06:03 PM
Pure5ty1e Pure5ty1e is offline
Ive got a 79 TA Special Edition, 400 4spd, with t-tops, Black + Gold. WS6 Pack. Emission systems removed. Holley 750. Electric Fans. Straight Thru' Exhaust. No A/C. etc
[This message has been edited by Pure5ty1e (edited 06-21-2000).]
Old 06-20-2000, 10:47 AM
78400TX 78400TX is offline
I have a 78 400 TH350 WS6 with headers and duel exhaust so far
78 400 T/A 6.6
2001 Z/28 Six speed
Old 07-03-2000, 08:42 PM
Druid Druid is offline
I have two original 1977 T/A's. 400 w/ auto. Black exterior w/ hurst t-tops. I even have the original spare tire and t-top bag for one on them..
Old 08-26-2000, 11:16 PM
rphel rphel is offline
I have two 1979 10th Anniversary Trans Ams. Both have 400cid engines, 4 sp manual, t-tops, and are silver of course. They are all original from what I can tell. I have acquired both in the last two months. I need interior restoration parts on one. This forum is probably going to get a lot attention from me. Thanks!!
Robert L Phelps
Old 08-30-2000, 07:56 AM
DOC DOC is offline
I have 3,
#1 , 69 Firebird, 350/2barrel completly stock and driven daily by my wife
#2 , 78 y-88 (painted pearl white), Daily driver for me 6.6/ auto
#3 , 78 hardtop, 455/t350, (motor built by Dan Whitmore) custom paint/interior. PST poly suspension, 4wheel disc brakes. and a ton of other show/hot rod mods.
Old 08-30-2000, 08:28 AM
i suppose if you're going to count older birds. 68 convert,350 th350.
former." --Albert Einstein
- Winston Churchill
Old 08-31-2000, 05:05 PM
Eric Schattschneider Eric Schattschneider is offline
Here is mine: follow the link
http://www.0rdernet.com/Mean_Pontiac...s/78ta38.2.jpg
If you go back one. you can read my story.
Old 08-31-2000, 08:58 PM
Dave Kovar Dave Kovar is offline
70 TA Lucerne Blue 4 speed 3:73
Took out original motor and put in a 70 455 block. Ported heads. Stock Ram Air III intake and carb. Ultradyne cam and HS 1.65
4 tube header and sidepipes. Haven't to track but runs 108 on G-tech meter
Dave
Old 09-09-2000, 06:07 PM
SiberWolf SiberWolf is offline
78 TransAM, 400, auto with Hurst shift kit, Martinique Blue, blue vinyl interior, 15x10 Cragar SS rims on rear, 15x8 on front, Hurst t-tops, Heddman headers, Holley 650cfm spread bore carb
nice hole where the AC used to be (didn't work, and was in the way so i pulled it), and 2 missing chrome sail panel birds (somebody decided to steal em right off the side of the car a couple months ago)
I'll put some pics up on a webpage as soon as i take some and get my hands on a scanner.
SiberWolf
Old 12-10-2000, 08:42 PM
Chris Baillie Chris Baillie is offline
I currently have a 79 T/A was 403/Th350 but am looking at a couple 400's. It's loaded including t-tops, and is black with white.
I also have a 73 T/A with number matching 455 and m-21 with 3.42 positrac.Bucaneer red with black standard interior, no options. The 455 is bored .30 over, balanced and bluprinted comp cams 292H series cam with complete roller valvetrain, a performer RPM intake and holley 750 dp carb. looking at RRE aluminum heads and possible stroker kit.
Old 12-12-2000, 12:30 PM
78 Trans Am 78 Trans Am is offline
I have a black TA, WS6, but without the hipo 400. It has a Turbo 350 tranny. The car is in great shape, and I am looking to put headers, true dual exhaust, cam, intake, rebuild the carb, and invest in some higher compression heads. Also looking to possibly install a stron 200r-4 tranny, along with some deeper gears, hopefully a set of 3.23, or a little lower.
Now in search of money for the ponies I have been looking for.
Old 12-27-2000, 05:55 PM
Rashionality Rashionality is offline
79 Pro-Street Trans-AM
731 horsepower 455 built by
http://www.krepower.com
Wenzler high Ports, Comp Cams roller, Victor, Dominator, TH400 w/ 9" converter, 12-Bolt w/ 4:11's
Best pass with Street tires and full exhaust (over the axle)
10:12 @ 134 MPH (no nitrous)
"Take your time, don't live too fast, troubles will come and they will pass...
Old 01-03-2001, 05:17 PM
firechicken's Avatar
firechicken firechicken is offline
'78 Trans am 400,068 cam,headers,ported and port matched 4X heads,super T-10 4 speed,3.08 trac lock. Also '73 Formula TH 400 ,looking for a 455. Not a very original car so I'm building it my way!
  #38
Old 01-15-2001, 10:25 PM
Banditone Banditone is offline
77 SE ( BANDIT ) T/A .O3O 455 --ported 6X heads-RAM AIR CAM-rare red int.etc.--Sure got a lot of looks when I ran it down to the muffler shop with open headers.Has run 13 teens before the HEADERS-WILL be adding a high stall converter--SEE YA PARDNERS !!!!!!!
[This message has been edited by BANDITONE (edited 04-26-2001).]
Old 04-18-2001, 05:48 PM
willyv willyv is offline
I just aquired the same vehicle a couple of days ago and am interested what you will be pushing with your new engine. I'm in the process of removing the engine and sending it out for a complete rebuild/upgrade. BTW, I was really lucky to find this jewel completely untouched by kids and in the most complete state it could be in. But it's been in a garage undriven since 1989.
Willy
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Tim David:
I have a 79 T/A 10th Anniversary.
400cid. 4-speed. putting the engine together
now. 068 cam. .030 over. balanced. 1970
intake and carb.Complete rebuild.
Doing a full restoration.
Thanks,
Tim
<HR></BLOCKQUOTE>
  #40
Old 04-21-2001, 03:46 PM
pontiaddict's Avatar
pontiaddict pontiaddict is offline
68 Firebird - Currently frame off w/525hp 455
75 T/A - 400/412hp, Cameo white, blue birds, black interior, runs 12.90's
84 T/A WS6 - 5.0 305, Loaded, Black w/grey interior.
