Old 03-11-2003, 11:03 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Tom, Should I bring you a few Asprin when I come up to Det. in 2 weeks?
My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 03-12-2003, 06:06 PM
AIR RAM AIR RAM is offline
A pree lube will do little if nothing for the lobes. This is why you should keep the RPM's up to 2500-3000 RPM's. The lobes get oil from splash and a good primming will only get the bearing surface. I use Moly Lube every time, It is thick and sticks to whatever it touches. I change my filter and oil after breakin (50 60 miles) then I will change it again at 100. I hope I never have to go through a cam lobe problem, Good luck I hope you are able to get the people who are responsible to cover your loss.
SPEED SAFE, AIR RAM
Im putting together a .040 455 with Edelbrock heads (72cc), Eagle Rods, FLAT top J&E Pistons for 12:1, Harland sharp roller Rockers, Fluidampner, Edelbrock Performer RPM intake, and 750 Demon Carb. "GOT TRACTION"
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 03-12-2003, 06:28 PM
Malky Malky is offline
What about inadequately cleaned engine? Are the cam lobes not the part of the engine with the most marginal lubrication, and so most likely to wear rapidly if there is particulate in oil?
Old 03-12-2003, 08:42 PM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
Always good to wash the cam before installation. I have noticed most cams come out of the wrapper "gritty" feeling.
Old 03-12-2003, 10:51 PM
Tim Corcoran's Avatar
I would say it could be from too much seat pressure on the valve springs. Shouldn't be more than 120 psi. Ask your builder how much seat pressure he set the springs at. I would hold the engine builder responsible.
Tim C
65 LeMans, 3600lb. all steel, full interior, D-ports and a flat tappet cam, 11.01@120
Tim Corcoran
Old 03-13-2003, 08:02 AM
Half-Inch Stud Half-Inch Stud is online now
Moly Lube..."ain't this boogey a mess" - F. Zappa
Old 03-14-2003, 05:48 AM
PONTIAC DUDE's Avatar
in the past two weeks..
No problems.
Build it fast, build it right, build a Pontiac.
http://PontiacDude.cc
Old 03-14-2003, 05:53 PM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
Got to do it yourself! That,s the only way you know it,s right! Poor guy! got a mess on his hands!I,ve never had a "comp" go bad on break in.
Three motors Huh? My days are filled with fixen these new cars... Now you guys are having fun!
"GTO? Good Times Only!!!" "Get Tools Out!!!"
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
Old 03-14-2003, 11:30 PM
retrojoe's Avatar
retrojoe retrojoe is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> do like I do and wedge an aspirin tablet into the thermostat. It'll dissolve away, and your car won't get headaches.
<HR></BLOCKQUOTE> So if you used a Tylenol P.M. would you then have a sleeper motor?
My other life has meaning....
"It beats pickin' cotton and waitin' to be forgotten"
