Old 08-15-2005, 04:12 AM
T-Mac T-Mac is offline
Default Pic of my new intake setup
Just got my engine back together, again.
I decided to give the "Gutsram" a try.
This intake needed lots of attention to make it fit.
I also had a custom top made, the carbs sit at an angle so that the throttle bores line up with the port runners.
This top is about half the weight of the stock cast top as it was cnc'd out of a piece of 6061 billet aluminium.
If there is anyone that has used one of these that has any tuning information to share it would be appreciated (including the N2O fogger).
I was also able to install my new timing chain set, with the torrington thrust bearing, that I got from Scott Simms of "Simms Performance".
I must say that this is a quality piece and the directions that are supplied with it are clear and precise. Thanks Scott!
Hopefully I will get the time to get this setup dailed in soon.
Todd
Old 08-15-2005, 07:35 AM
Chris Roach's Avatar
Chris Roach Chris Roach is offline
looks good, what's the combo?
1969 GTO Judge Ram Air III
1968 Catalina "Darkside" Vert!
Old 08-15-2005, 10:30 PM
Hi Chris,
13:1 compression 475 (stock 455 block)
Ported E heads
Comp cams solid roller cam
GRP rods
Ross pistons w/ total seal gapless rings
Eagle crank
Gutsram w/ two 750cfm carbs and NOS annular discharge nozzles
Todd
Old 08-15-2005, 11:50 PM
Ron's Avatar
Ron Ron is offline
Is this my friend Todd from Reno???
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 08-16-2005, 12:47 AM
Wink Hey Ron!
Hi Ron,
Yes, it is I.
With the new board my screen name now shows up as my login/user ID.
I don't mind it so much, it will just take some getting used to.
Todd
Old 08-16-2005, 05:43 PM
Hot Rod's Avatar
Hot Rod Hot Rod is offline
Ron,
You have friends?
Only kidding! The Intake looks Sweeeeeeet!!!!
Rodney
"WELCOME TO THE NO SPIN ZONE!"
www.outlawpontiacdragseries.com
Old 08-16-2005, 07:22 PM
60man's Avatar
60man 60man is offline
I have a Gunstram I want to try myself.
It's a stock block 455(464)
KRE alumimum heads CNC ported
UD solid flat tappet cam 249/259 @ .050
Presently runing dual AFB 750's on a Offie intake..
Just wondering how much I would loose on bottom end response/power..if any ??
Also want to go to 2" primary tubes on headers,,if I can find a set !!
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 08-16-2005, 07:38 PM
White Warrior White Warrior is offline
60's man. The Gutsram is pretty tall and has large ports. It may stick the carbs thru your hood. I ran one for a while with both 750 AFB's and BG Demons but went back to my Bathtub intake because it made the same HP and was shorter and lighter.I tried 3 sets of Holley/ BG carbs and ran as fast or faster with my AFB's. The Bathtub with AFB's was 22 lbs lighter thsn the Gutsram with BG Demons.
I think what you need is a roller cam with about 276-280 duration and .650-.700 lift.
Dave
Old 08-16-2005, 07:59 PM
60man's Avatar
Dave
Agreed .....but first I need a rotating assembly that will take it !!
ECM member.
MANDRA
Old 11-16-2005, 02:12 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
Todd
Damn..........that looks like a race car "hot rod todd"......very nice.....and fast.
