Old 10-25-2005, 10:35 AM
helmerrock helmerrock is offline
Post Body weight 67 post car
I'm getting ready to pull the body off frame finally! All the bolts are out (only one broken). I have somewhat limited space to work so I've designed a special rack to hold the body that will allow the frame to roll out for work and roll back for storage. The rack is basically made from a heavy duty industrial steel holding system which I modified, trimmed and welded on casters. I need to know how much the completely stripped 2dr post body weighs so I can figure out the best way to lift the body onto the rack. Can the body be lifted with 4 guys? I could get my hands on an oversize cherrypicker and use straps etc. Any suggestions on best, easiest, safest way to get this done? Thanks for any input.
Old 10-25-2005, 12:46 PM
rzrektd rzrektd is offline
On Vacation
I lifted my 66 hardtop with 4 guys. This included lifting about 200 lbs worht of racking. The guys were not burly. I can lift body and rack at either end by myself without a problem. Guessing maybe 500-700 lb shell at the most
Old 10-25-2005, 03:03 PM
merlotgoat's Avatar
merlotgoat merlotgoat is offline
I thought this was an interesting way to lift a body...
http://216.178.81.108/forums/showthread.php?t=457012
Old 10-25-2005, 03:08 PM
A-body A-body is offline
I've seen guys that hooked chains from front to back seatbelt mounting holes. Push an engine hoist thru the window and hook to the chains. Jack it up. Use your help to keep the body from spinning.
Old 10-25-2005, 04:10 PM
Thumbs up
Thanks for the great responses!! Let's see...how many beers does it take 4 guys to lift off a body??? That could get expensive!!! Fork lift in my 1 1/2 car garage....I've got almost enough room to walk now so that won't work, besides my forklift is 20 miles away. ABody....now that sounds like great idea!! I was looking at using a hoist above the roof and never thought about using the seat belt mounts. I'm on the move with that idea. Thanks to all!!
Old 10-25-2005, 04:56 PM
On Vacation
it is indeed. I lifted my body off by myself. cut body bolts. Jacked car up by the frame. Supported body lowered jack. Snake chassis out the side halfway. Resupport body to snake chassis the rest of the way out.
1.5 hour process for the removal not including disassemble.
Old 10-25-2005, 09:33 PM
6704gto's Avatar
6704gto 6704gto is offline
when i took the body of the frame on my 67 hdtp completey stripped it took 4 guys
Old 10-25-2005, 10:55 PM
Bryan Jensen's Avatar
Bryan Jensen Bryan Jensen is offline
On Vacation
Send a message via AIM to Bryan Jensen
Exclamation
Woah woah woah WOAH!!!
Hold up guys, this needs to be done in a careful matter!!! I agree with members most of the time, but you don't want to make a GTO/mechanic sandwich in your garage
I just uploaded some video I shot with my camcorder back in January to document my "redo"...this should give you a good idea of how it's done and what a successful body off the frame ends up being...I just uploaded this to putfile.com so you guys can get an idea.
If you've got a buddy who has an car lift and a huge shop (like I did, it will be significantly less stressful and more enjoyable)
Click here to watch last-look-at-GTO-before-sandblasting
Click here to watch 67-GTO-coming-off-the-frame
Click here to watch prep-before-body-removal
By the way, excuse the guy's "bowtie on the brain" mentality from the guy with the beard in the videos...he's a chevy guy to the core, but he really lent me a hand in the early parts of my disassembly and gave me access to tools at his shop I didn't have
I may be only 18, but I know the right way to do this without problems. hope that helps!
Old 10-26-2005, 08:46 AM
On Vacation
There is always more than one way to skin a cat and always a safer way.
Old 10-26-2005, 04:39 PM
GTOster GTOster is offline
24 cinder blocks 3-8' 4X4's posts me and my son one block at a time
Rolled the frame out did floor pans, trunk and one crossbrace frame blasted new springs,shocks,fuel and break lines Eastman chassie black Undercoated shell new body mounts and she is back on the frame all in 30 Days
Now my wife was not happy with all the long nights But I got it done It will go to a body shop for primer and paint at the end of Nov then come on Spring
Paul
