Old 11-18-2005, 02:15 PM
mikediaz mikediaz is offline
Originally Posted by johnsma22
Natural gas radiant heat would work great for your needs. The radiant heat type does not heat the air, it heats the objects in the room. No blowers either.
John
well i think it would still heat the air up, since air is an 'object' if u will, however you are correct otherwise in the sense that 'radiant' heat is not what we're used to (convection or conduction) where heat has to transfer more or less physically by two things touching or a gas touching something.
point of the story: i think the air gets hotter too but that doesn't change your point at all!
p.s. i may be wrong about all this
