Old 11-24-2005, 06:42 PM
BDHABT's Avatar
BDHABT BDHABT is offline
Default To tube or not
I need some advice.Do you guys run tubes in your slicks?I had the ET streets,and never had a problem.Now I switched to the ET drags,and they leak like mad.I was told not to run the tubes cause they add weight,(makes sense),but I`ll do what I have to do,and lose the weight somewhere else.Any comments are appreciated.The tires in question are 28x11.50-15.Thanks,Mark.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 11-24-2005, 07:51 PM
screamingchief's Avatar
Most folks running slicks without tubes use soap on the insides of them to keep the leakage down I believe.
Or something of that sort...
Old 11-24-2005, 07:59 PM
WARPed's Avatar
WARPed WARPed is offline
I for one use tubes, one less thing that needs to be chased after. I would be curious if anyone has ever done any testing on the difference between the two setups. I am sure there would be some difference but how much in a heavy (+3000lbs) car? Of course one thing you have to have is screws in your rims when tubes are used for obvious reasons.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 11-24-2005, 09:52 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
I use no tubes in my 28x11.5x15 Hoosier Quick Time Pro's. I have them screwed. I've had no leakage problems, but I do use Palmolive dish soap to coat the inside of the tires before I mount them. I used to run the same tire but smaller, and when I drilled the rims for screws I used Dawn, and it did not work as well. Just my $.02 My car weighs 3370 with me in it, and I run 17-18 psi.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 11-24-2005, 09:55 PM
Jagtec1's Avatar
I just read this...you may find it interesting.
http://216.178.81.108/forums/showthread.php?t=459852
Darin
9.81 @ 136.39MPH
Old 11-24-2005, 10:05 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Yes use Palmolive, I took the tubes out of my 15-11.5W back when the car was running low 10s@ 3450# and I picked up .06
Its rotational weight so that makes it even better if you can get rid of it.
[email protected]. 3460#s
Old 11-24-2005, 10:23 PM
WARPed's Avatar
The 69GP has tubes in the 14x32x15’s but the altered I am building has 33x16x15’s with out tubes and leak like there is no tomorrow. I am game to try the Palmolive dish wash. So what is the “Palmolive procedure”? Just rub it in on the inside of the tire? Dilute with water and slush it around or what?
1994 Formula
Old 11-24-2005, 10:28 PM
RAIV55 RAIV55 is offline
I don't run tubes, taking them out improved both ET and MPH.
In my opinion any slick should be screwed to the rim. (Unless you have bead locks)
I read that link about improving 60' times with tubes. I'm still scratching my head on that one.
Didn't know about the dish soap.... thanks for the tip!!
Old 11-24-2005, 10:54 PM
WDCreech's Avatar
WDCreech WDCreech is offline
I just soak a cloth with Dawn and wipe the inside of the tire. My son says he he mixed his soap solution, about 4/5 water, 1/5 dishwashing liquid. Both of our tires are still up. We quit racing after Labor Day.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 11-24-2005, 11:21 PM
Scott65's Avatar
Scott65 Scott65 is offline
Reaction times are improved sometimes with tubes. If you're not pro tree racing that's not really an issue though.
Old 11-25-2005, 01:41 AM
02Hawk's Avatar
02Hawk 02Hawk is offline
I have run with and without tubes. Did not notice any difference. Also I thought that screwing the tires was more old school and wasn't necessary any more. The tires and wheels are both better quality. I don't see the pro guys doing it? I mark to see if the tire slides on the rim at launch and then add a pound or so more of air to slow the slide.
Old 11-25-2005, 02:13 AM
johnta1 johnta1 is online now
The real Pro guys run beadlocks.
Most other people are using screws, with even more on each side.
Used to be about 5-8 screws a side. Now about 10-15.
Warped, maybe your beads on the slicks are burgered up.
Have to make sure the people that mount them know what they're doing.
I run about 5.5 lbs in my slicks and the next week they still have 5.5 lbs.
I won't go back to tubes.
Old 11-25-2005, 03:27 AM
BVR421's Avatar
BVR421 BVR421 is offline
I used a sponge to completely coat the inside with Dawn. Let dry overnight, another thin coat and mounted. Worked for me.
Old 11-25-2005, 06:29 AM
Jagtec1's Avatar
My tires were moving about an inch per pass when my car was only going 11.70's. I ran 17-18 psi. That's when I decided to screw them. Any movement is too much in my opinion...dangerous.
Darin
9.81 @ 136.39MPH
Old 11-25-2005, 10:33 AM
SlowSpitzer's Avatar
SlowSpitzer SlowSpitzer is offline
I have not used tubes in years, maybe 10. I use the dish soap before, but forgot this time. New 14.5X32 Goodyears. Still up yesterday, been a month.
Steve
Yea, I know, the heads suck!
2005 Cordova Q16 Winner!
2005 Norwalk Sat Top ET Winner!
Old 11-25-2005, 04:49 PM
Torment's Avatar
Torment Torment is offline
I've run with and without tubes and had different results with different slicks. I run tubes in my Phoenix 28x10.5" as they are more stable on the top end and consistent (stiffer) off the line. Seems to depend on the tire and the car - no one answer. My Firebird weighs in at 3750lbs with me in it.
My first set of Phoenix slicks leaked air right out the sidewall without tubes...kind of made the decision easy.
The secret to happiness is not getting what you want but rather, wanting what you have.
