Old 12-01-2005, 08:05 PM
ronpontiac ronpontiac is offline
Thanks for your input. So far I found two machine shops from Hemmings Motor News that says they can save the drum. One says they will press in a new sleave then bore it out to the correct dimension. Another shop says they would weld the damaged part then bore it out. I don't know which would be the better solution or they might be just as good. Any advice? Thanks.
