Old 01-29-2006, 04:59 PM
T-Mac T-Mac is offline
Question 12 Bolt Rearend Gears
Does anyone know of a source for 3:55 ratio 12 bolt gears for a 4 series carrier?
Thanks, Todd
Old 01-29-2006, 08:47 PM
GoatDr GoatDr is offline
Richmond's lowest gear(numerical) is 3.73 for a series 4.
GoatDr
Old 01-29-2006, 10:32 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Todd,
Nobody makes a 3.55 in a 4-series carrier. I did alot of calling around before I bought my 3.73's and everyone said the same thing. I believe that you can machine down the ring gear to get it to fit...but I've heard it's a pain in the a$$.
-Brian
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 01-29-2006, 11:00 PM
Originally Posted by bad69bird
Todd,
-Brian
Thats what I am hearing as well.
Did you get any quotes on machining the ring gear down?
Maybe one of the gear vendors would provide the extra service.
I am running 3.73 gears now.
Todd
Old 01-30-2006, 01:17 AM
bad69bird's Avatar
No, but a friend of mine, who has a chassis/paint & body shop, called around to try to see how much it would cost to get a bulk order of the 3.55's machined down to fit a 4-series carrier. I think he said the cost for the gears would be in the ballpark of $500.00! I'm not sure if that was consumer price, my price, or his cost. I didn't get a price on just machining down the gear. I went through the same dilema. I didn't really want to put 3.73's behind my blower set-up because I figure that I would be going through the traps roughly at 7800-8000rpm. Oh well...what can you do.
-Brian
Old 01-30-2006, 04:57 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
The 3.73 gear is pretty thin. I'd hate to see how thin the 3.55 gear is.
Old 01-30-2006, 05:51 PM
BVR421's Avatar
BVR421 BVR421 is offline
I just replaced 4.56s with 3.73 the 3.73 is REALLY THIN! LOL
last $$ I will spend on this damn 12bolt. I could have had a custom 9" for what Im in the 12bolt and its still nothing to brag about
Old 01-30-2006, 07:27 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
I just replaced my 4.10's with 3.73's on my 4 series carrier. I really doubt anyone makes 3.55's, I looked around pretty good, Strange, Richmond, US Gear, etc. Now if you were going the other way uou could use a spacer. Just use 3.73's and a taller tire, that is what I did. -Jim
Old 01-31-2006, 03:22 AM
-Brian
Brian,
$500 seems a little steep for the gears.
At that rate it might be a better path to sell the existing setup and seek a 9 inch.
Are you spinning your engine to 8000 rpm now?
What is the bore and stroke of your engine, what crank and rods are you running?
Todd
Old 01-31-2006, 03:35 AM
Scott, BVR and Jim
Yes, the ring gear is thin and that is definately a concern.
I guess maybe I should be asking for a 3 series spool instead of 3 series gear to fit the 4 series spool.
IS THERE A 3 SERIES SPOOL AVAILABLE?
By the way I am running the tallest tire that I can find (30.9")
Thanks, Todd
Old 01-31-2006, 09:31 AM
bad69bird's Avatar
Originally Posted by T-Mac
Brian,
Todd
Todd,
The cost is why he didn't go through with the deal. I just put 3.73's and was done with it.
My redline is 7600rpm, but I'm figuring that I will be going through the traps between 7800-8000 Once I burn up the DR's (275) that I have I might trim my wheelwell alittle, so that I can put a 295 DR on it. My bore/stroke is 4.350/4.00, rods are Olivers, and the crank is a Moldex billet.
_Brian
