Old 12-10-2005, 05:42 AM
indie's Avatar
indie indie is offline
Send a message via AIM to indie
Arrow Information on chevy - firebird conversion
I am seeking information that explains what is needed to be done to convert both a first generation firebird and a second generation firebird (70-73) to using a chevy 350, in particular a ZZ4.
Old 12-11-2005, 12:23 AM
nonnova's Avatar
nonnova nonnova is offline
Location: Cleverly Disguised As A Responsible Adult In The Motor City
V8 frame mounts from a 67-69 Camaro or 68-74 Nova for the first gen., V8 frame mounts from a 70-81 Camaro for the second gen. (I'm not sure if any other models fit the second gen.)
Fuel lines for the Pontiac motors run on the drivers side and the Chevys run on the passenger side, and a compatable trans as the BOP (Buick/Olds/Pontiac) trans has a different bellhousing pattern then a Chevy although there are dual pattern transmissions out there or adapters available.
1974 Oldsmobile Omega: '73 Pontiac YX code 400, 4X-7H Heads, Edelbrock cam/intake,
Holley 750 dbl pumper, Dynomax headers, 2.5" 50 series Flowmasters, M20 Muncie 4spd,
8.5" 10 bolt with Auburn race series posi, 3:73 gears and 4 wheel disc brakes
Looking for the right Ventura for the drivetrain ('73 w/o Sprint nose)
Old 01-30-2006, 02:44 AM
sts sts is offline
A Pontiac tranny will bolt up to a chevy engine, but a chevy transmission will not bolt up to a Pontiac engine.
Old 01-30-2006, 08:50 AM
pontiac locator pontiac locator is offline
why not just buy a camaro????????
Birds, Boats, or Goats as long as its a PONTIAC!
Old 01-30-2006, 05:35 PM
engineer engineer is offline
For these years, a Pontiac trans will not bolt up to a chevy engine, and a chevy transmission will not bolt up to a Pontiac engine. Only much later BOP had some dual patterns to fit onto chevy.
Old 02-03-2006, 01:00 AM
firebird69racer's Avatar
firebird69racer firebird69racer is offline
dont forget the starter is on the other side also, and some times the ALT. is in different loacations too. there are adapters to bolt the BOP trans to the SBC. you will also need all the A/C, P/S,and ALT brakets for the SBC, as all the pulleys, the fan shroud will be different too.
Wade
Old 02-16-2006, 11:37 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
yes...please do
Old 05-24-2006, 06:01 PM
pontiholic pontiholic is offline
Default SBC into 1genFB
I have a 69FB w/ a 400sbc/auto (I bought it that way) that I would like to switch back to Pontiac. Car ran 13.2 in SLC UT however I may be interested in a swap. Steve 801 358 7636
Old 05-25-2006, 02:16 AM
indie's Avatar
*note* i asked this question when i was going to buy a car w/o engine and trans. I have 350 Pontiac now and wouldn't have it any other way.
1973 Firebird 350
Old 05-25-2006, 08:58 AM
Mr. P-Body Mr. P-Body is offline
Indie,
Smart choice... ZZ4s are not what they're cracked up to be, as is true with most of the GM factory "craters". We've seen tremendous issues with cranks and valve trains with people trying to treat these craters like REAL race engines.
IMO, the only "good" crate engines (Chevy) come from Dart, World and Eagle. BIG money...
Jim
Old 06-29-2006, 12:04 AM
twisted's Avatar
twisted twisted is offline
Send a message via Yahoo to twisted
Originally Posted by INJUNTOM
yes...please do
If you guys are so against putting non-pontiac motors in pontiacs, then why do you even read this section of the forums?
From a finacial stand point I don't think I can afford to put another Pontiac in my bird, and thinking about putting a Chevy in it too.
In over my head..and getting deeper..
Old 06-29-2006, 12:33 AM
7T2 7T2 is offline
From a finacial stand point I don't think I can afford to put another Pontiac in my bird, and thinking about putting a Chevy in it too.[/QUOTE]
chevy motor eh? hmmm-
wait a minute! whats this under my shirt on the center of my stomach?
why, looks like ive got one too!
gee- that IS cheap.
you chevy guys are right.
Old 06-29-2006, 12:56 AM
twisted's Avatar
gee- that IS cheap.
you chevy guys are right.[/quote]
Lost me, what do belly buttons have to do with anything? We all have buttholes too, but you don't see anyone pointing that out....
