Old 02-20-2006, 03:26 PM
6T9GTO's Avatar
6T9GTO 6T9GTO is offline
Default Rear End Braces - 4 speed
I just bought this set of rear end braces for my 69 4 speed convertible. Does anyone have a picture of these installed?
Thanks,
Bill
Old 02-20-2006, 04:08 PM
steve v's Avatar
steve v steve v is offline
Bill,
I think they go from the forward upper control arm bolt (in front of the rear cross member) to the forward lower control arm bolt. You may have to take your upper bolt out & reverse it if the nut isn't on the front side of the rear crossmember.
I'd post a pic from my factory manual for you but my scanner just took a dump.
HTH,
Old 02-20-2006, 04:28 PM
6T9GTO's Avatar
Thanks for the info, Steve. You wouldn't happen to know if the slotted end goes to the upper or lower mount?
-Bill
Old 02-20-2006, 04:55 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Here's a good pic:
Old 02-20-2006, 05:23 PM
6T9GTO's Avatar
Thanks Rick, that's just what I was looking for!
Old 02-20-2006, 06:42 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
Bill...where did you get the braces for your '69 GTO?
I have the reinforcement braces for the 1966-67 GTO's but need a set for my '69 GTO also.
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 02-20-2006, 08:00 PM
Jeff's Avatar
Jeff Jeff is offline
Thumbs up Repros
Ames sells repros for 79$ or so, I believe PY has them also.
Old 02-20-2006, 08:18 PM
Shadowjack Shadowjack is offline
I just put a pair of eBay specials on my '67 a couple of weeks ago. Little did I know there is more than one length...but after a session with the Sawzall and MIG, they're just right! Missing 2 solid inches though--I have no idea what they were really off of. Slotted hole goes on the lower bolt, BTW, won't fit any other way.
Old 02-20-2006, 09:47 PM
TJH TJH is offline
The longer ones are for 1968-72, I believe.
You can find them on ebay for slightly cheaper money, but often they end up getting bid up to what the new repro parts cost (stupid, but true).
I got lucky when I was looking for some for my 1970. I found a mis-worded ebay ad, and ended up getting the braces and some control arms for something like $20.
Old 02-21-2006, 10:31 AM
6T9GTO's Avatar
I scored my set off Ebay. Sold by Bethel's Goat Farm. I paid $42 plus shipping.
-Bill
Old 02-21-2006, 12:04 PM
my69gto's Avatar
my69gto my69gto is offline
I've never seen those .... what were they used for? Assisting traction?
Old 02-21-2006, 01:04 PM
69goatboy's Avatar
69goatboy 69goatboy is offline
They were factory installed on cars with MTs. Supposedly to help tie the frame together during "spirited driving" (hard launches).
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 02-21-2006, 02:13 PM
my69gto's Avatar
so... they could also help with "spirited driving" in T-400 cars I presume????? Are these the same as some kind of "traction assisting devices"(not sure what they were called) that were available on 68's??? I read a thread somewhere about something from the factory on 68's to help in launching as you mentioned above...
Old 02-21-2006, 08:35 PM
They were installed on manual trans cars to reinforce and triangulate the control arm mounts on the frame so loons who did a lot of burnouts wouldn't crack the mounts off the frame by dropping the clutch... Not sure you'd get the same shock loads into the frame with an auto.
Old 02-22-2006, 02:41 PM
robz's Avatar
robz robz is offline
I believe they were only installed on Manual tranny GTO H/T only, not conv..I had them on my 69 4 speed H/T, but never saw them on any 69 GTO Manual tranny convs..probably since conv had the boxed frame, they weren't needed.
Old 02-22-2006, 03:48 PM
69goatboy's Avatar
If you have a shift kit in your TH-400 or just like to drive hard, I'd put the braces on. At about $65 (# RPU80A from our host) they're cheap insurance.
Old 02-22-2006, 04:50 PM
tajunkman's Avatar
tajunkman tajunkman is offline
Junkyard tip- I have found a few 68-72 el caminos including automatics that had these braces.
Old 02-23-2006, 02:43 AM
CDN2PLS2 CDN2PLS2 is offline
Oshawa built Lemans have them.
Old 02-23-2006, 09:23 AM
Matador-IV's Avatar
Matador-IV Matador-IV is offline
In the picture shown above, I believe the bars are actually mounted upside down.
The middle section of the bar that is "folded" back should be downward to provide clearance for the mufflers. That driver side bar needs to be turned over and mounted to the pass side.
Old 02-23-2006, 03:17 PM
6T9GTO's Avatar
Robz,
They will still physically bolt up in a convertable won't they? If not, I may have a set for sale!
