I went to check on my block and crank at the machine shop and I was suprised. My stuff has been there for three weeks and I needed to see the progress to order my pistons. The machinest said, "what block did you drop off and let me see if I can find it." My crank and block was in the back corner of the shop untouched! I was floored. He said that he didnt see it under some boxes he stacked on it. Anyways he said he was going to get it done next week. I guess when people are paying 800 plus bucks for porting BBC heads and stuff, they come first. Thats what he was doing when I walked in. I was a little pissed, but I did order some goodies today. I ordered my speed pro pistons, cat rods, balancer, and flexplate. I just need some rod bearings and he will be able to balance my assembly. Just thought I would vent a little. Maybe next week I will have some good news.
1976 trans am. 400 .040" over stock crank, CAT rods, speedpro flat tops, 72cc eheads, rpm intake, quick fuel 750, xe274, 1.5 HS. Built 700r4 (by me) w/3200 EDGE converter. 3.73's hustler headers. Flowmaster exhaust system. 17" torque thrust II's |
ON the CAL AUTO TRANSPEED (CAT) rods :: I just had a set, balanced and installed, after oh 8 min of run time, took a look at the bearings, they had wear "lines, wide ones .
seems the crank end is BORED and has boring rings throughout that showed up as wear as the bearing conformed to the rod end. bearings toast. I would STRONGLY suggest either getting better rods, or getting those RE-SIZED AND balanced. Mine were off my a total of 10 grams total (thats huge in my book) any set should get a balance, but the extra cost for resizing might just put you in a better rod price range.
" Long may we DRIVE !" |
Ive been debating on rods for a while now. I decided on the cat rods because of my budget. They are going to the machine shop as soon as they come in. I know about the ends needing attention. Thanks for the input.
They're fine, IF the crank was chamfered after it was turned, that raised the holes. run a fine double cut file over the chamfers, then polish.
You ALWAYS chamfer prior to turing the crank. Pontiac Gregg
Greg Merrick |
What Greg said...
Also, 10 gr. adjustment for an I-beam rod is nothing. Stock rods are seldom that "close". This WHY we balance engines! H-beams are generally more consistent, as they are 100% "machined". Same is true of the high-dollar I-beams (like Manley, Oliver, etc.), NOT including Crower Sporstman. While still a very good rod, the Sportsman is an "unfinished" I-beam, leaving material inconsistent along the beams. A simple balance fixes it. Yes, check the big end, and have it honed. A hone produces the most desirable finish, and will maintain "round" much better than a boring machine. Jim |
I purchased a set of these rods last year for my 400. The crank end had a honed finish on them out of the box. I mic'd them for size and indicated them for circularity and everything looked good. I did stone all the edges of the machined surfaces though as they were a little sharper that desirable. I also installed the bearing shells and torqued to spec. Mic'd again and had .0025-.0029 bearing clearance across the board on +.010 bearings. I have since had the engine apart and the bearings looked fine. All rods checked within several grams of each other too. Average 6-7grams with two a little bit heavier than that. I did not check for hardness though. For the price I've found these to be a decent rod. Just spend some time cleaning and preping them.
