Old 03-14-2006, 06:31 PM
69 redbird's Avatar
69 redbird 69 redbird is offline
Default trans. ????
I have a 69FB w/350 eng. Would I get better gas milage if i change mt trans from a 3 speed to a trans with OD? and will a OD trans fit and mount right up?
Old 03-15-2006, 04:59 AM
bastereo bastereo is offline
yup, you will get better mileage on the freeway
look to classic chevy 5-speed for a tko with overdrive
they have kits with every part needed to swap it over, my friend just installed his kit from them last week and everything went great (and the new trans is amazing)
Old 03-15-2006, 03:24 PM
69 redbird's Avatar
Default thx
I called them and all they have is tranny's if you want to convert to a 5 speed manual. I would like to keep it an automatic? Do you think a 700R trans. would fit?
Old 03-15-2006, 06:28 PM
Bruce1223 Bruce1223 is offline
Yes, I believe a 700R4 will fit, but I think you will have to modify (shorten) your drive shaft. You might also check into a 2004R auto. I think this is a smoother swap than a 700. If memory serves me, it will should swap in about like a th350. Check out www.firstgenfirebird.org and do a search on the subject. There has been quite a bit of discussion on this swap there.
Good Luck, Bruce
