Old 04-08-2006, 06:23 PM
cnc's Avatar
cnc cnc is offline
Default Ram air hood repair
Just picked up a ram air hood for my 70 Bird the vent fingers are broken and some missing the left corner is cracked but not broken off what is the easiest/best repair.....Thanks
Name:	ram air hood 001 (Small).jpg
ID:	49291   Click image for larger version
Name:	ram air hood 002 (Small).jpg
ID:	49292   Click image for larger version
Name:	ram air hood 003 (Small).jpg
ID:	49293   Click image for larger version
Name:	ram air hood 004 (Small).jpg
ID:	49294   Click image for larger version
Name:	ram air hood 005 (Small).jpg
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 04-08-2006, 08:30 PM
68droptop's Avatar
68droptop 68droptop is offline
I would thing the easiest thing for the fingers would be to cut the whole section out of another hood and butt weld it into that one. I'm not sure about the corner. I can't really tell from the pic.
Jeff
Project "Thanks Dad!"
Old 04-08-2006, 09:22 PM
issach428's Avatar
issach428 issach428 is offline
you could lay a fiberglass mat on the back side coat it with resin an let it cure. This would strengthen the strips. Then take a dremel bit and carefully cut out the open areas. Thats how i would go about it.
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
Old 04-11-2006, 08:11 AM
BAW'D GOAT BAW'D GOAT is offline
If you're interested in doing some intricate welding, I have 2 GTO hoods that are solid in that area. It would require shortening the ribs as it looks like the birds are shorter as well each Goat hood has 18 ribs so it would give you something to work with. If you're interested PM me.
Old 04-11-2006, 08:38 AM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
This is a fiberglass hood right?
Old 04-11-2006, 10:37 AM
TJH TJH is offline
It would be kinda difficult to weld steel to fiberglass...
Me? I would have found a better hood...
Old 04-11-2006, 12:23 PM
cnc's Avatar
cnc cnc is offline
yes its fiberglass came with the car so any other suggestions???
Old 04-11-2006, 12:25 PM
cnc's Avatar
cnc cnc is offline
HEY BAW'D GOAT were u located in London....I'm off springbank Dr
Old 04-11-2006, 12:30 PM
I have a very nice Formula hood . Its difficult to repair the vent area on those hoods , thats a common problem. 68droptop if you figure out how to weld fiberglass to steel please let me know also
Old 04-11-2006, 12:43 PM
cnc's Avatar
cnc cnc is offline
I have seen a hood were they filled the hole area in.....
Old 04-12-2006, 08:19 AM
CNC, I'm located on Ridout and Tecumseh, just moved to London bout 6 months ago. Didn't realise the hood was glass, sorry. With with some fiberglass matting and resin, some careful layout and some quality time with a dremel and you should be in good shape. Matting and resin available from Crappy Tire. Be interested in seeing the car sometime. Gonna be at Wortley Village this summer?
Not really all that difficult to attach metal to fiberglass, you guys never heard of moulded body kits?
Old 04-14-2006, 01:08 AM
mrsiding mrsiding is offline
I have a 71 formula. It had the sme problem. I filled the whole area in and it looks good. Also found it much easier to sand and paint. I think it actually looks better without the vents. Plus I don't have to worry about them being broken again. I think you would find that filling the section in will be a lot more practical if you want to use that hood.
