conton 3qtr accusump installed and ready to go. Watcha think..
Is that a one way check valve installed at the block adaptor ???
If so please read my post in the race section on the valves. If not please disregard
Working on going faster (and now staying dry at the same time !!) |
no check valve here ,your looking at the pressure sender port coupler.
the oil will be prewarmed for your protection.
is this thing on? |
I have a question reguarding the fuel system...It seems as tho you have the main fuel line coming in the front of the carb, and the regulator at the back AFTER the carb sees the pressure...Is this a better set up than running the fuel line to the regulator and then out to the carb?
Im asking because im planning on putting my regulator at the rear of my carb,, but I was going to run fuel in through regulator first and then to carb and bypass out of regulator...whats best?> this is for my turbo deal Mike |
