Old 04-24-2006, 11:18 PM
Bandit79403Dave Bandit79403Dave is offline
Default Second Gen vs 4th Gen Weight differential? Legally save weight in 2nd Gen TA
Hey All...
I know I was one of the people to bring this up in the past but I figured I would bring it to the front of the pile again as I am finally in a position to make a legit run at TCI/FAST Pro Stock. I have my heart set on one of two cars: running a second gen TA or a 4th Gen Firebird. I currently have a '70 TA clone that would be a good candidate for this build as I have a motor that can run the numbers. My problem is that the car has to weigh in at 2935 pounds...that being the case, I would need to somehow shed 500+ pounds out of this car as I believe it weights close to 3500lbs...not to mention its 200 lb driver isn't at the helm. Seriously looking at a second gen, I know I could lose a lot by gutting the doors; changing the wheels, tires and brakes; gutting the impact bracing; running 'glass bumpers; fuel cell; lightweight seats, drivershaft, powerglide; no AC, heater, etc...lighter control arms...while this seems like a lot I am not sure I can make the weight. After doing a sizeable amount of computation and running the numbers on this motor, at 3200 lbs I am still at roughly 8.80s-8.90s but realistically speaking I am sure I can add a few tenths to that...at 2900lbs I am looking at 8.60s.
That being said, I also have the opportunaty to sell off all my other stuff, including this '70 clone car and use a 4th gen bird...I believe I can get the car lighter than the '70 and I feel it is more aerodynamic. Couple that with the wheel base and where the engine falls in that wheelbase and I think I really have the posibility of making something happen.
I guess what I am looking for is some guidance...safe ways to cut weight and be able to maintain structure. What have all you guys done.
Again, I thank you a million times over in advance!
Take care!
BanditDave
403 afficionado...made it my personal quest to maximize the power potential of the 403.
www.fcrperformance.com
Old 04-24-2006, 11:54 PM
Brian Baker's Avatar
Go with the 4th gen...it's a no brainer. Easier to get the weight were you need it, and the body has a lower drag coefficient.
Old 04-25-2006, 12:03 AM
I know Bri...for some reason though I can't get rid of these damn cars...I just keep holding on to them...haha....
Old 04-25-2006, 04:00 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Some of the older 4th gens can be had pretty cheap. Look around you should be able to find a great deal on one somwhere. I think I saw one on racingjunk.com a few days ago for cheap.
Old 04-25-2006, 08:33 AM
PONTIAC DUDE's Avatar
Post 2nd Gen cars are:
FWIW:
Too heavy if ya got to run stock type suspension.
4th easier to get lighter then the 3rd gen.
The later 3rd & 4th have better stock type suspension systems to work with for better 60 ft'ers. Strut fronts and 4 link backs.
Check the BMR Fab website. Best out there for replacement 3rd & 4th gen stock type stuff.
Aero is better with the 3rd over the 4th.
