Old 05-26-2006, 08:04 PM
Turbo Indian's Avatar
Turbo Indian Turbo Indian is offline
Default have I lost my mind??
my wife is wanting an older Firebird. but she has also looked at Volkswagen diesels, because of the fuel economy. so I have come up with a real strange idea. I think yall have guessed it, a first gen bird with a VW turbo diesel. I'm willing to bet it would be the only one in the world. many will say the bird is to heavy, but a friend bought his wife a VW beetle & that damn thing was around 3900#'s. no it would not be the fastest thing on the road, but it would be peppy & get great milage. lets hear why it wouldn't work.!
67 firebird, RPE built 274ci TA Performance Buick V6 block, [email protected] with just a few bolt ons, & a 275 DR.
anyone can restore 1 it takes a real man to cut 1 up!
99 Western Star 500hp 52' lowboy Mid Atlantic Heavy Hauling
Those Old Timers That Think...
There Is No Replacement For Displacement
Do Not Know What Boost Is.
Old 05-26-2006, 09:06 PM
BVR421's Avatar
BVR421 BVR421 is offline
other than smelly and slow?
Im hard pressed to come up with a good argument against it
anything is reversable if you want to change later
I would look around for a 6cyl Perkins, plenty power and weight about the same as a Pontiac motor.
Old 05-27-2006, 06:21 PM
Bad Karma's Avatar
Bad Karma Bad Karma is offline
I have been beaten in one of my other 350 PONTIAC POWERED LEMANS by a VW TDI. It may be slow in a big car but It would definately get good mileage.
72 Lemans
Old 05-30-2006, 04:32 PM
Northern Goat's Avatar
Northern Goat Northern Goat is offline
Aren't VW's front wheel drive? Would that be hard to convert? If it works let us know I will buy a FB and do the same, would be a great commuter car. I think you would have to get used to all the shade tree mechanics telling you there is something wrong with your car. Would defintely mess them up though.
WORK HARDER. Millions on welfare depend on you.
Old 05-30-2006, 08:39 PM
yes they are FWD but, if there is a will there's a way. as for the weight, a 67 bird weighs less than a new TDI Beetle!!! I do not know if I will do this but it shure would be a great daily driver!!! 40+ mpg out of a 1967 model car?.!
Old 06-01-2006, 10:43 PM
Donovan Donovan is offline
How about doing a drivetrain transplant from a Turbo-diesel truck? I bet it's get great mileage in a Firebird and still haul as$. Then you would also have the big aftermarket support they get. This might also help make the swap easier? Being that you'd have access to programmers etc.
______________________________
1968 Firebird Coupe - 3665 lbs.
350 HO
Long Branch Manifolds
TH350
3.23 open BP axle
PS, PDB and Deluxe interior
GPE Starter ... Small body HEI ... 2.5" Pypes w/X-pipe ... Ruggles Qjet
14.1 @ 99.1
Old 06-02-2006, 03:17 PM
Originally Posted by Donovan
How about doing a drive train transplant from a Turbo-diesel truck? I bet it's get great mileage in a Firebird and still haul as$. Then you would also have the big aftermarket support they get. This might also help make the swap easier? Being that you'd have access to programmers etc.
several reasons why that idea wouldn't work. but here are a few.
1) to heavy (would never get traction with 3/4 nose weight)
2) to large I don't think you would get it to fit without heavy modification.
3) mileage would not be feasible, maybe 24 mpg?
Old 06-02-2006, 03:20 PM
Bad Karma's Avatar
Dodge cummins turbo diesel comes in 5.9 flavor. that shouldnt be too big to fit but then again it is uncharted territory here.
72 Lemans
Old 06-02-2006, 10:58 PM
The curb weight on a Beetle TDI is only 3,005 pounds. The first-gen birds outweigh it by at least 500 pounds. Would definitey be the slowest thing on the road with 1.9 liters and 100 HP.
Peppy?
Those newer VWs don't stay out of the shop much from what I've read. A new VW (diesel or gas) would be close to last on my list if I was buying an econo car.
Put together a nice OHC 250-inch Pontiac six for it, twice the power and should get better than 20 MPG. At least it won't make people gag when you open the hood.
