Old 06-03-2006, 12:32 PM
1967 GeeTO 1967 GeeTO is offline
Default Driveshaft removal
How do I remove the driveshaft on a '67 4-speed car? I would like to clean it up.
Also, what is the correct paint? Aluminum? Spray Gray? Detail Gray?
Old 06-03-2006, 04:39 PM
6tee7goat's Avatar
6tee7goat 6tee7goat is offline
Send a message via AIM to 6tee7goat
At the rear of the driveshaft remove the two U-bolts which attach it to the pinion yolk. Make sure the caps stay on the U-joint and don't fall off. Then just push the driveshaft a little forward into the tranny and the rear should drop out. Then just pull the driveshaft straight back out of the tranny.
The driveshaft was left bare steel from the factory. If I recall I used Detail Gray on my past one which most closely resembles the steel. But my memory may be a little hazy.
Old 06-03-2006, 04:54 PM
69 goat's Avatar
69 goat 69 goat is offline
Just a little FYI:
You should also mark the the flange and cap so you can re-assemble the way it came apart. Sometimes if you don't you can cause a "new vibration".
Also if you jack the car up under the rearend it will help with fluid coming out of output shaft area on trans. If you don't have a set of output shaft plugs or a old yolk to use.
Good luck
Old 06-05-2006, 11:47 AM
Thanks!
Old 06-07-2006, 10:15 PM
Bill H's Avatar
Bill H Bill H is offline
Default Stripes
If you want it to be factory correct I believe the driveshaft for each model had 2 colored stripes painted on them. It' in the service manual but I'm not home to look at mine now but will post later if you want the info.
Old 06-10-2006, 09:47 PM
Thanks. I have researched the correct colors and will duplicate them.
Old 06-10-2006, 11:29 PM
bullheimer's Avatar
bullheimer bullheimer is offline
mind if i ask: who's gonna see it?
I no longer have that beautiful 66 in my Avatar. whaaa!
When a cat is dropped it always lands on its feet. When buttered toast is dropped it always lands with the buttered side facing down. If a piece of buttered toast was attached to the back of a cat, when dropped, the cat/buttered toast combination should hover, spinning just above the ground, as it tries unsuccessfully to resolve the inevitable conflict of non-scientific certainties.
Old 06-12-2006, 10:44 PM
karl emerick karl emerick is offline
"mind if i ask: who's gonna see it?"
just knowing it's there seems to dampen vibrations and gives a comfort...
