Old 07-09-2006, 06:53 PM
Mats Mats is offline
Question Best fitting headers for a 78 Fire Bird?
HI,
I have just built my first Pontiac.
Rebuilt engine, freshly painted and it's all good.
Except an annoying ticking noise form the engine bay.......
Sounds like a valve ticking but it isn’t. leaky headers.
Can you guys tell me ho has the best fitting headers?
Any suggestions?
Mats
Sorry For my bad english
Old 07-10-2006, 12:11 AM
gtoformula's Avatar
gtoformula gtoformula is offline
I've heard good things about Doug's Headers, but I am running Hooker Competition headers (not super comps). I have had no problems with installation or leaks. I'd avoid the style that have one center tube (for the 2/4 and 3/5 exhaust ports) instead of two separate tubes.
Old 07-10-2006, 08:38 AM
PONTIAC DUDE's Avatar
Post
No issues and installed a set of 1 3/4" Headman header on the wifie's car in under 2 hours.
I used the Felrpo performance gaskets.
Old 07-10-2006, 04:22 PM
ChrisTransAm78's Avatar
ChrisTransAm78 ChrisTransAm78 is offline
Are you sure that's what's ticking? Get a vacuum cleaner hose/tube and run it around till you find exactly where its coming from. A header will also leave carbon where its leaking from. Assume 6X heads?
Chris
http://www.christransam78.com/
Old 07-10-2006, 05:31 PM
goldbird*12.82 goldbird*12.82 is offline
Send a message via AIM to goldbird*12.82
Thumbs up
78 t/a 1 3/4 headmans
Old 07-10-2006, 06:21 PM
berrygoat's Avatar
berrygoat berrygoat is offline
I'll chime in for the Headmans as well. Recently pulled the original 400 from my 77 TA. I bought the car with 1 3/4 Headmans already on. They were way easier to remove/install than the SuperComps on my 69 GTO.
Old 07-10-2006, 10:50 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
like my hedmans, too.
great ground clearance and nice fit; well made for cheapie headers.
far better ground clearance then hooker supercomps.
i crushed both lower primaries on both sides flat on my hookers; not cool.
i'd spring for ceramic coating if you can afford it.
is this thing on?
Old 07-12-2006, 11:28 AM
Hi, log in problems. Tank’s guys
Yes it’s 6x head’s. Did what you told me Chris, it’s leaking around cyl 1 8 and 7. Some carbon residue on the gasket.
So you are all satisfied whit hedmans or comps?
Ceramic or natural?
Whitc engine setup’s do you run whit1¾ header’s?
Thanks again
Mats
Old 07-12-2006, 11:45 AM
Got some pictures.
Old 07-12-2006, 11:48 AM
ID:	58702   Click image for larger version
Old 07-12-2006, 01:33 PM
Larry Navarro's Avatar
Ditto.
Hedman #28150....1.75" primaries, 3" collectors.
Old 07-15-2006, 11:06 AM
Thanks Larry
do they make them with ceramic coating?
78 Firebird. 0,30 400 cid, speed pro domed 0,125. Xe 274. Eagle H rods. fully balanced. ported 6x heads. Rpm inntake . 800 edelbrock. prepped th350 whit 3000 stall.
Old 07-15-2006, 01:31 PM
Thumpin455_GTO's Avatar
Thumpin455_GTO Thumpin455_GTO is offline
paper gaskets are junk. Dont even bother with them. I like the felpro gaskets, and you gotta keep them tight.
You can get headers coated, even if they arent offered with it. I wont buy another set that isnt coated.
Old 07-15-2006, 01:58 PM
I use the papers, here in Houston I had a problem with the metal sandwich in the FelPros rusting , staining headers and heads, adding rust to header bolt threads. My papers don't do that.
Old 07-15-2006, 05:13 PM
It's too bad that Percy's don't make those seal-4-good dead soft aluminium gasket's for Pontiac's. Anybody tryed Percy's XX Carbon Exhaust Header Gaskets?
Old 07-15-2006, 07:29 PM
Originally Posted by Mats
Thanks Larry
No.
Trial fit them first to make certain there are no clearance issues, the most noted is the small area arond the lower left control arm bracket on the subframe. Mine needed a small dimple there but that was it.
I then sent them to Airborn Coatings, $205 in and out.
www.airborncoatings.com
Old 07-15-2006, 10:04 PM
nice! wow !!!
Old 07-16-2006, 03:21 AM
form406's Avatar
form406 form406 is offline
im using reused paper gaskets with the copper sealer...no leaks...my cheap hookers are alright except the drivers side collector triangle points up..had to modify my floor pan a bit...i cut the flanges as well...which cut install time to 1.5 hours...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
