Old 07-30-2006, 03:31 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Originally Posted by lust4speed
We added headers later and that really gets interesting with the stock 65 crossmember. We cheated - bought a 67 GTO convertible crossmenber off ebay and added about 3" on each side and just added a little bracing. Now have 3" extensions coming straight back from the header collector back to the cutouts and the 2.5" X-pipe. No-one notices the new crossmember unless I point it out to them since the center section and the area around the pipes is Pontiac correct - just a different year of being correct. Other mods I have seen done scream out that there has been a massive alteration to the crossmember. I would bet that a 67 big car convertible crossmember would have possibly fit with no extensions, but gave up trying to find one since we had a Pontiac points race coming up and needed to get it back together.
You might be able to use an open frame crossmember if you went this route. That should be about 3" total longer. Would probably have to modify the ends.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 07-30-2006, 07:03 PM
lust4speed's Avatar
We had an open frame 67 GTO hardtop cross member for comparision. That sucker was almost a foot longer than the width for the 65 Cat piece - plus we needed that one to go back into the 67 so we didn't want to cut it up. Really surpirsing how much longer the open frame cross members really are, and shortening them presents other problems since you get into the angled U part of the cross member really quick.
Old 08-03-2006, 09:31 PM
63RedCat's Avatar
63RedCat 63RedCat is offline
Default Catalina Exhaust
Here are pictures of a Pypes exhaust on a 65 Catalina. Had to modify the crossmember to fit. Turned out well though. Used Race Pro mufflers, nice rumble.
ID:	60906   Click image for larger version
ID:	60907   Click image for larger version
ID:	60908   Click image for larger version
ID:	60909   Click image for larger version
