Old 08-09-2006, 07:48 PM
slowbird's Avatar
slowbird slowbird is offline
Default header evac?
Has anyone had any issues with a header evac system sucking lots of oil into the headers?
Old 08-09-2006, 08:58 PM
russ467's Avatar
russ467 russ467 is offline
I didnt have that problem, but mine was building too much pressure in the crank case and blowing out my valley pan seal when running a header evac system. Took the hoses off the breathers and the problem went away. Didnt make any difference in my et.
70 Formula
Old engine:
467 HO headed
6.79 1/8th mile @ 101.87 no N20. 1.44 60ft
6.23 1/8th @ 111.83 w/nitrous
1.37 60ft
New Engine
IAII 535
Calvin Hill Eheads
Few test passes made. Tore it up. Just got it fixed.
Old 08-09-2006, 10:29 PM
WDCreech's Avatar
WDCreech WDCreech is offline
russ467, If your evac system was causing crankcase pressure, it wasn't installed correctly. They are designed to create a vacuum, not pressure.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 08-09-2006, 10:47 PM
screamingchief's Avatar
I agree,either that situation was already building too much crankcase pressure and the evac system simply could'nt "keep up" and relieve the pressure adequately,or the evac system was'nt functioning properly due likely to either a faulty check valve or an improperly installed collector probe.
JMO/FWIW.
Installed properly the breather/seperator the evac system has on the valve cover should collect/stop most any oil in theory,but if you're the paranoid type,and/or into overkill style practices,it would be very easy to take a puke tank for a vacuum pump style set-up and use it as a collection tank for any stray oil that may get past the breather/seperator.
Just run the breather hoses to the puke tank,and from the puke tank to the collector probes,only catch is you gotta plug or use the fitting for the breather most of those evac tanks use.
Remember,you dont want the breather for this purpose,the system must be sealed and able to hold a vacuum so the evac system will continue functioning properly.
Most of the breather tanks only have one inlet,so likely you would just use the breather hose fitting for the other hose needed to use it like this.
Take for example a tank like this stef's piece,loose the breathers completely,one set of hoses from the breathers would go to one set of inlets,and the other set of outlets would go down to the collector probes,a tank like this would be perfect IMO,as long as you can find the room for it,and plumbing is'nt too complicated.
That or use two smaller tanks,each for a seperate side,but serving the same function...
Anyhow,ya'll should get the basic idea,so I'll leave it at this.
Bret.
ID:	61504   Click image for larger version
Name:	Copy of mini tank.JPG
ID:	61513   Click image for larger version
Old 08-09-2006, 10:56 PM
Old Man Taylor's Avatar
I have not had any problems with mine.
Old 08-10-2006, 12:52 AM
lust4speed's Avatar
I just recently installed mine so I've been watching them pretty close. The engine is staying clean and the outlets inside the collectors look good. They seem to be doing their job well.
Old 08-10-2006, 01:56 AM
BrandX's Avatar
BrandX BrandX is offline
Just installed my header evac tonight....going from electric vaccum pump off of a crown vic to this new set-up header evac. I allmost think they both create the same amount of vaccum, I am gonna do a back to back at the track to find out.
Old 08-10-2006, 09:54 AM
Ron H's Avatar
Ron H Ron H is offline
I found highway driving sucks oil into headers. That is 3400 rpm steady for a half an hour. I do not have baffles in my valve covers and they are the old M/T kind so they are short. If you have a taller set and can plumb from the front face of the valve cover with a baffle I can't see any issues.
Otherwise street driving and at the track I have no issues.
68 Firebird
Are you running with the wind or breaking it?
Old 08-10-2006, 12:35 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
I have no problem either. Maybe it's time to do a leak down test. Too much blowby?
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 08-10-2006, 02:11 PM
rocky's Avatar
rocky rocky is offline
I been running the evac system now for atleast 10 years not a problem at all
Old 08-10-2006, 06:48 PM
slowbird's Avatar
Ron H just how much oil do you think is being sucked into the headers on yours. Ours is street driven with the M/T valve covers (like yours) but with a 1/2" spacer under them. I can see some oil, maybe a quart every 500 miles or so. Also the engine is fresh with maybe 600 or 700 miles on it.
Old 08-10-2006, 09:13 PM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
If your building enough pressure to blow it out the valley pan, you need new check valves. They tend to stick in a few years, especially if it isn't started every weekend. Take off the hose at the breather and blow on the hose. If your cheeks blowup you need em. The local "good parts house" sells one for a Ford that is the same as the one that come Je's or Sum's kits. 14.00 ea. to Joe Blow, and about 1/2 that if you have a relationship with them.
uh-o left myself open again to Rob B. ridicule. Oh well He'll turn it into a gay thingy, cause I said Joe Blow
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 08-11-2006, 01:49 PM
Sicbird Sicbird is offline
Does anybody run header evac with full exhaust? A couple of you said you run it okay on the street, but I had to ask... I'm planning to run Ultraflows and a 3/4 or possibly full exhaust. Just wanted to make sure it would work well with that. Plumbing a tank between the valve covers and headers should be easy enough.
Old 08-11-2006, 02:02 PM
Ron H's Avatar
I have full exhaust that I uncap the cut outs at the track. Pypes full 3" with race pro mufflers on a 68 firebird.
I would say the amount is very little getting into my exhaust pipes but it is enough to cause smoke. I drive on highway. Stop at a store. Restart car and a huge bellow of blue comes out the exhaust pipes. But rev it and put it in drive and it's gone.
I am sure this will be eliminated when i put the sheet metal valve covers I ordered with the evac holes coming out the front.
68 Firebird
Old 08-11-2006, 02:19 PM
russ467's Avatar
Actually it was a brand new kit. It pulled plenty of vacuum at idle, but either my exhaust was building too much pressure to keep it from sucking, or couldnt keep up with crankcase pressure. I am running Total Seal rings and there has been discussion about excessive crankcase pressure using those rings.
70 Formula
Old engine:
467 HO headed
1.37 60ft
New Engine
IAII 535
Calvin Hill Eheads
Old 08-11-2006, 05:54 PM
I ran mine through a 4" exhaust system for most of the years I raced that combination. The mufflers are the Racemasters.
Old 08-11-2006, 07:29 PM
I've also read several post on PY that said the same thing. Try a site search, if you can figure it out. I seem to get nothing that pertain when I search here.
Might be short valve covers with no baffles too.
I run the dreaded Moroso tall (although there is a trick to them) and use no baffle to 6000rpm. No problemo.
NHRA tech.
