Old 08-18-2006, 11:51 AM
verytaylor verytaylor is offline
Thumbs down 8 bolt water pump overheats :(
Does anyone have any output on the 8 bolt pumps this 67 GTO has run hot for 34 years and now even hotter with a new motor! Do ya scrap this for the 11 bolt pumps or can they be tweaked to cool better??
Old 08-18-2006, 12:40 PM
george kujanski's Avatar
Welcome.
Go to the top thread in this forum. It's titled "chalk one up for the cast impeller". it's a long read, but the first few pages should give you some ideas.
George
Old 08-18-2006, 01:15 PM
GRX's Avatar
GRX GRX is offline
Yes, what George said. That thread is a good read. But that applies to the 11 bolt design. Not certain the same applies for the 8 bolt.
Anyway, here is a page which shows the heart of the matter ::
closing the gap between the impeller & the divider plate ~ http://www.wallaceracing.com/water-pump-mods.php
Hope that helps your cooling issue.
Old 08-18-2006, 01:28 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Pulley size?
Shroud?
Fan?
Heating up at idle or running down the road?
........I'm just learning as I go.......
Old 08-18-2006, 02:14 PM
david400's Avatar
david400 david400 is offline
I have had the same problem also on my 68 she just runs hot in the summer time .i dont drive it if it is above 85 out .however i am looking foward to tweeking my plates .
Old 08-18-2006, 02:36 PM
BVR421's Avatar
BVR421 BVR421 is offline
mine gets hotter than hell. 220 plus I just keep driving it. It didnt hurt it to run hot in 1968 and it wont now..
Actually, I am such a liar, the last few years I just dont drive my old cars in the summer daytime because they dont have AC. Im not concerned with the motor just my own comfort. (8-)
Old 08-18-2006, 06:28 PM
Old Goat 67's Avatar
GRX, you are incorrect, those pictures on your link and the original post by George here on this board (page 1) were pictures of my 8 bolt pump!
Charles
Old 08-18-2006, 10:50 PM
GRX's Avatar
GRX GRX is offline
Guess it was the 2nd and 3rd lines on that page which threw me off.
> " This basically applies to the newer 11 bolt water pump. The older water pump is designed differently and may not apply. " <
Seriously though, the 8-bolt set up is nearly identical so should work. Which is what you were trying to say I believe. Thanks Old Goat.
