Old 11-06-2006, 03:43 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Jim- with the al. heads on your engine, even with the bigger cam is it possible it was still starving ( need bigger cam and non factory intake -rpm?) - hence the poor performance?
  #62
Old 11-06-2006, 04:05 PM
Jim Hand Jim Hand is offline
Performance Pontiac Author
John,
Are you asking that if I had changed the engine and car to run higher RPM, would the heads have worked better! Just as explained above, an engine needs a certain amount of airflow to run to a certain RPM optimally.. And airflow over and above that will make no difference in power. However, in order to get that excess airflow, the ports will have to be enlarged, and that most certainly will affect engine power.
And I did not get "poor" performance from the KRE heads - to the contrary, they performed very well indeed. - best of 11.69/115.5. But just not as good as the small port iron heads did!
I didn't install the heads with the idea of retooling the car to optimize the performance of the heads. I installed them in order to have new modern trouble free parts that would also remove a bit of weight.
If I had wanted to change the RPM range of my engine and car, I didn't need to buy new heads - I could have simply ported my iron heads for more flow and bigger ports!
Incidentally, I was running the RPM intake at all times with the KRE heads. And the cam I was running was my regular cam of 234/244/112, and not the 041. the new custom cam was specifically designed to add the low RPM power lost by the bigger port s on the KRE heads. And it did that, but unfortunately a 108 LS cam of only 233 degrees also quits making good power much earlier in RPM then a 112. Accordingly, what it picked up in the lower RPM, it lost in the upper RPM, besides idling much worse!
Jim Hand
  #63
Old 11-06-2006, 04:08 PM
70 lucerne lemans's Avatar
70 lucerne lemans 70 lucerne lemans is offline
Ron H,are you running 93 octane?Im calculating my compression ratio closer to 11.5 to 1 with the KRE 74 cc ,zero deck 468.Hoping to run 93 octane or mix some 100 with it if I need to.
Mark
1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD....
1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs
(1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor
[email protected] on 150 shot
  #64
Old 11-06-2006, 04:29 PM
Ron H's Avatar
Ron H Ron H is offline
I am at 4400'. My pistons are .012 in the hole. I have SRP pistons -8cc eyebrows. 4.181 bore, 4.121 stroke.
I will be 50/50 112 with 91 for racing. Otherwise on the street I am ok with normal driving. Though I did detonate a bit on a run this morning again.
Being in Florida I bet you will have to run at least straight 104 unleaded or a 50/50 110 or 112.
68 Firebird
Are you running with the wind or breaking it?
  #65
Old 11-06-2006, 04:33 PM
ponjohn's Avatar
poor vs the 6x heads.
  #66
Old 11-06-2006, 05:17 PM
Bruce K Bruce K is offline
It's difficult to have your cake and eat it too. I for one have noticed a difference from 6x to E-heads. With the ported 6x's and the small roller 224/230 low rpm throttle response was incredible. Now with the big cam 252/262 and 235cc E-heads [email protected] the engine is not happy below 1500 and is lazy up to around 3000 rpm.
I am still trying to work out some carb issues (with a lot of help from shaker455ho) to help idle and off idle response. Even in a perfect world it will not be like the old combo.
Would I trade and go back, I don't think so! The rush from 3750 to 6000 rpm is worth the price of admission. I can deal with a higher idle and a little bucking if I fall asleep and try to drive it like the old combo. The engine is more comfortatable at 2500-3000 rpm cruise than the other engine was. It doesn't make any more temperature than the other engine, but is a lot harder to start and keep running when cold.
It won't cruise happily below 1500 rpm in top gear, more like 2000 to really get things flowing. Even if it did, I would never try to accellerate hard from that low of an rpm in 4th gear. That's what lower gears are for at low speeds.
The Car and Driver 30-50 mph top gear acceleration - what a joke. If I trusted anyone enough to drive my car and they did that test, that would certainly be the last time they drove any of my cars.
I can just see myself going 30 in 4th and pulling up to a Corvette or Viper and nailing it.lol And then they test an auto vs a manual. What a useless test, how about a 30-50 in 1st or second gear, that might be a meaningfull test.
Forgive my ranting and back on the subject. It's all what you want, I happen to enjoy the 12mph I picked up in the 1/4, btw, I think it will be more like 20mph when I'm done tuning, and am willing to give up some of the low rpm friendliness of milder combo. Life is about tradeoffs and think if someone wants that feel of hp and the feeling that your engine wants to keep pulling hard up top it is a worthwhile tradeoff.
'79 T/A 6.6 4-sp, 3.23 , 463" E-heads, 252/262 hyd roller, TII, Holley 830, 8.384 @ 93.86 - 1/8, 12.5 @ 116 - 1/4, 2.035 60', 3800 lbs. w/o driver
  #67
Old 11-06-2006, 05:51 PM
Bruce,
Exactly! Everything is a tradeoff, and what suits one may not suit another. And that is the beauty of our hobby.
But as this is an information board, all of the related information needs to be posted on any subject, and that is what I am attempting to do with facts, figures, references, and reliable comparisons.
Jim Hand
  #68
Old 11-06-2006, 06:25 PM
Jim, I have been reading your articles and posts for many years now and will continue to do so. I and I'm sure most here have great respect and gratitude for the time and energy that you have put forth and your willingness to share information is totally unselfish. You could put what I know into a thimble compared to what you know, but I am working on my 4th engine combination now and just thought that I would relay some of my observations to the board. Thanks, Bruce
  #69
Old 11-06-2006, 08:32 PM
Jim I know you don't want to turn much rpm over what your motor does now. Your goal has always been to stay under that 5500 rpm ceiling. That's fine and you've gone as fast as anyone else with your strict guidelines.Alot of good tuning got you there and intelligent selections. I know you've gone even faster with yours in a different configuration. We all have goals and what we want out cars to do, look like. Mine is to keep a Shaker on the motor and go fast on pump gas and be streetable, I don't think there are too may out there that can stay up. I probably could pick up with a Victor, but that looses my main guideline. I'm not arguing that the KREs ran slower on your car or that yes increasing rpm range you could have gone even faster. That wasn't your goal and they didn't meet your needs.
Jim you may not have done it as a head test BUT I think almost EVERYONE here read into your results that the 185cc ports were why it ran slower, and because of their slower velocity and no other variables were possible. "As a result of the loss of low and early mid range power due to the larger ports on the KRE heads" Right there it says the big ports are the only potential problem! It was very strongly implied that any motor with similar cam range(within 3 degrees @ 0.050), D port heads, intake, carb would also NOT benefit from the change using the bigger ports because yours did not. Cliffs is as close to your combination as possible other than not the same exact heads with the same exact flow. OK cam was 3 degrees different @ 0.050. Which is virtually impossible unless we use CNC ported iron heads.Hence the comparison, and discordant results, and no loss in bottom end feel. In fact Cliff's less ported heads should have had smaller ports than yours and gone even slower. Other folks are also going faster. So it is not just the port size for every car! Most other ported D ports that flow similar to yours are going to be closer to 180cc so probably less velocity, so no way are anyone else's going to perform the same as yours using the same logic.
Variables -Put a 6X-4 head next to a 6X-8 and a head gasket against both. They aren't the same chamber. So if your before ported iron and after D ports were different castings we have the potential for a variable. Recent magazine tests even question our 1 point difference in aluminum vs iron compression. But no one questions the loss of heat and HP in an aluminum head vs iron head, unless barrier coated at the saem compression. So that is one vairable on yours eventhough you tried to keep the compression a non variable. So even different castings are a true variable. You can't striclty say the port size was the factor on yours!teh different port shapes in even the ported iron heads much less the KRE head's different shapes add a variable to the cylinder filling independent of the port cc! The chambers are an extention of the port and affect that also and are different so another variable.
I go back to Pontiacs round port vs D port 455 port size which you have never even commented on. How did Pontiac keep their rpm range similar if 30cc impacts them that much, or did the increased flow or different chamber do it? The same difference in the KRE and your heads and fewer other variables. What's the reasoning here?
OK we will approach the concept small ports flowing the same as big ports. You will know all of this as well as I, as much as you read, it's not that simple! or I guess I'm just really dense!
Velocity theoretically would be increased, BUT if it too much vleocity we make fuel fall out of suspension, packing the cylinder with air and less fuel/air combination needed for HP. Most head gurus, Vizard included, feel getting close to sonic speed velocity is BAD. What is the velocity in a small port on a 465ci motor when running? Will ALL the air in the port be able to make all the short turn at the higher velocity? Or will some of it collide or tumble making flow go backwards, easily heard on the flow bench. Vizard has mapped velocity in SBC ports and reccommends porting more in those areas-do we know that for a Pontiac port? Which head's port? What is the velocity in your ports and in what areas? As I've stated before I'll be we don't have a map for any of our heads like Vizard has done. Do you know the velocity was slower over more of the KRE port than your 6X port? That's what we are assuming based just on port cc.
Why are the NASCAR, Pro Stock etc big guys finding even identical flowing , identical sized ports run different? They must run the same but they don't.That's where they go to the wet flow bench. Tom S even talked of having his RAVs wet flowed. Just the slightest difference in port shape chamber shape adds a variable into that and they can see it on the wet bench. On hand porting I'd bet even variables between different cylinders.
I had 4 totally different cams in the RAIV 400 and ALL ran identical to the 0.01 times & mph, only one killed the streetability and increased rpm range needed, a big solid. Different variables were at work.The cam was one, the exhaust header another.
  #70
Old 11-06-2006, 08:36 PM
Here's what Lynn just mentioned regarding velocity regarding a Pontiac Iron head with only 180ish cc
"The biggest positive in a race engine will be to keep the maximum flow velocity to 614 feet per second to minimize splitting the fuel out, and not choking down the intake charge.
My SS 455 engine calculates obout 769 fps in the push rod area. It seriously limits horsepower, RPM. "
So to much velocity is a bad thing also!
  #71
Old 11-06-2006, 08:48 PM
gearbanger's Avatar
gearbanger gearbanger is offline
Jim, I had never seen that information put together just that way before. I would suggest you lost performance because you switched from iron to aluminum and didn't increase the compression ratio enough. It is pretty well accepted that you need a full point more compression with aluminum due to the heat dissapation of aluminum. It's too bad you hadn't gone to 11:1 with your compression. I bet you would have had different results. You were probably about on the edge of being able to use pump gas with your origional combo, but the KRE headed combo would have probably run fine on 87. I just don't see it as a fair comparison of the KRE d's. Still good info, and as always, I love to read about your testing. Very scientificly done.
  #72
Old 11-06-2006, 08:58 PM
Gearbanger.
I have also heard that al requires one extra point of CR. However, I have never found one test that has been made that confirms or even hints at that much difference. In fact a recent test by Car Craft magazine tested an iron and an Al head from the same company with all variables on the heads, including CR, as identical as was possible to make and guess what! The two sets of heads made identical power even with the same CR!
If you know of documented tests and/or results that confirm that one full point is required to make equal power, please advise as to where they are and how we can access them.
Jim Hand
  #73
Old 11-06-2006, 09:01 PM
Ron H's Avatar
I think they just posted that in the Dec Hot rod that you have to make 1 more point of CR with aluminum to equal Iron. I will go home and read it now to confirm.
68 Firebird
  #74
Skip,
Just curious - at what RPM does Lynn apply a load on his engine, and at what RPM does he shift?
And did you look at the referenced material by David Vizard? I presume you did and you feel his testing is incorrect!
Jim Hand
  #75
Old 11-07-2006, 12:27 AM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
i believe the aluminum head "1 point rule" is that you can go a point higher in compression with aluminum vs iron heads with otherwise the same combination - ie, more detonation resistant due to the surface heat sinking faster then iron heads.
is this thing on?
  #76
Old 11-07-2006, 08:22 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
You beat me to it. So, If you can run another point, why not?
Jim, mill the heads and put them back on. We'll give you two weeks to come back with a full report.
  #77
Old 11-07-2006, 09:11 AM
Ron H's Avatar
I read though that way of thinking has changed. They said instead of you can run more, you have to run more to equal an Iron head.
68 Firebird
  #78
Old 11-07-2006, 09:23 AM
gearbanger's Avatar
Jim, the test would be the octane test. If you have to run supreme in your iron head combo, but your aluminum head combo didn't need that. Cliff's car ran quicker and faster with 89 than 93 with 10.5:1 compression.
I think the results of the test that you were talking about is probably because the aluminum heads had design features that improved the performance enough to offset the heat disappation effects of the aluminum. Had they raised the compression of the alum heads to have equal fuel requirements as the iron head, I feel sure that the aluminum head would have outperformed the iron heads.
In your case, your iron heads had been optimised for your combo and 93 octane fuel, so the improvements that the KRE heads have were not enough to fully offset the difference in fuel requirement. You simply needed more compression to exceed the performance of you iron heads. And that would have easily been possible with the aluminum.
  #79
Old 11-07-2006, 10:55 AM
Guys,
What and where is the "one point more CR" rule listed and documented?
I am sorry that the technical facts I (and many others) have presented about the effects of different port sizes on engine power are being disregarded. I fully understand we don't like to give up pre-conceived concepts about how to go fast.
I will close my portion of this discussion with this comment:
The next time anyone wonders why my 4070# wagon with 3.31 gears, a mild cam, and a Q jet can possibly be competitive with lighter cars running much higher flowing heads and larger cams, you may want to reread some of the facts I have posted and referenced. My car doesn't just magically run what it does by following pre-concieved ideas and "rules" that have no basis.
I have tried to help others understand the subject, and that is all I can do. I don''t have time or the inclination to argue about material I have tested and confirmed.
The KRE heads I bought and ran are long gone - I learned and confirmed all I needed to know about the effects during those weeks of trying to make them work at least as well as what I had.
As always, we should each build our cars exactly as we want them, regardless of what others say. So keep those Pontiacs running!
Jim Hand
  #80
Old 11-07-2006, 11:13 AM
scott70's Avatar
scott70 scott70 is offline
A good working combination is the name of the game!!!!Ive seen pontiac cars at my track with e heads and such and they couldnt come close to running with my 250 cfm iron headed car.A good combo VS a bad combo.I'm going to some ported jbp e eheads this winter but like last time,i'll tell him my entire car combo and tell him what I expect in the end and hope all ends up well.And it will end up on the engine dyno again to see the results.
