I want to go to an overdrive like you wouldn't believe!!
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Ahem. Theoretically, of course.
Badder than old King Kong And meaner than a junkyard dog -Jim Croce |
of course.
Do any of you guys use no-hop bars? Cause if i am accelerating moderately hard and go over a bump it gets bad wheel hop and I have to let off.
70 GTO 462 E-Heads TKO-600 9-Inch/3.60's |
I just put a set on and it made a big difference. No wheel hop on smooth pavement, but it did stiffen the ride some and I think on a bumpy surface it would jump around alot.
'79 T/A 6.6 4-sp, 3.23 , 463" E-heads, 252/262 hyd roller, TII, Holley 830, 8.384 @ 93.86 - 1/8, 12.5 @ 116 - 1/4, 2.035 60', 3800 lbs. w/o driver |
