Old 11-02-2006, 10:17 PM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Unhappy Can this tuned port be saved?
Found this at the boneyard. It looks to be all there, but somebody worked on it with a hammer.
I know the car's total, but can the motor be resurrected? Is it worth it?
Bob Trimpe
ID:	70398   Click image for larger version
ID:	70399   Click image for larger version
Old 11-03-2006, 06:25 PM
72LemansFreak's Avatar
72LemansFreak 72LemansFreak is offline
Hard to tell from the picture. I don't see a throttle body. If it's been worked over with a hammer, I wouldn't keep any of the parts above the intake. Get an aftermarket plenum and runners. Honestly, I wouldn't be surprised if you spend almost as much as a complete aftermarket unit to get this one going, but the intake, runners, injectors, harness, etc are worth taking if they are there.
Regards,
Henry
1989 Trans AM GTA
Brilliant Red with Dove Grey Interior
5.7 TPI/700R4 3.27 "Aussie" Rear
1972 LeMans with Endura Option
Lucerne Blue with Black interior and Black Vinyl Top
400/TH350 (Sold)
"Wind in my hair, shifting and drifting, mechanical music, adrenaline surge..."
-Rush, "Red Barchetta"
Old 11-05-2006, 08:48 AM
WW3's Avatar
WW3 WW3 is offline
You can buy an above average condition TPI(5.0-5.7) car for less than it would cost to fix this one up to being the level of a P.O.S. car.
former home of the 4-speed Can am
Old 11-06-2006, 03:37 PM
fyrebird68's Avatar
I'm looking for a TPI motor to put in my GTO. I would not EVEN attempt to resuscitate this car!
Bob
Old 11-06-2006, 06:41 PM
WW3's Avatar
WW3 WW3 is offline
I see...what kind of H.P. are you looking to get from a TPI powered GTO?
Unless you could buy that whole car for about $200 then it'd be allright for scavenging the harness and ECM, but I see no value with what's left of this TPI.
Old 11-07-2006, 01:46 PM
fyrebird68's Avatar
Not so much big HP, but more modern type performance and maintenance. I got used to working on my son's 91 TA, and the goat has a rod knocking, so I thought "why not".
Bob
Old 11-07-2006, 07:43 PM
WW3's Avatar
WW3 WW3 is offline
I like this idea..BUT... TPI's are H.P. limited because of runner size among other problems. So if your looking to propell 4000lbs with one it may be disappointing in the end. At best a highly modified 383 block with worked over TPI unit on top might yield just 350-400 horse. And after that you'll find your wallet lightened by a few thousand dollars.Not to mention the extensive prom burning that'll need to be done.
Maybe if H.P. isn't a concern then yes, a TPI engine is probably the least expensive of the late model F.I. engines. You could probably find a 350 TPI from a mid mileage car,complete with tranny,ECM for $800-$1500.Out of the box those produce about 255 H.P., which is nothing to sneeze at but they were in 3400lb cars.
If H.P. is a concern then maybe a better suggestion would be an LT1 from 93-96 or even a newer LS series small block.
You know what would be the cat's a$$... a 2005 or newer 6.0 LS2 out of a wrecked late model GTO! I can see those "GTO" plastic shrouds and everything in your GTO!
That might be pricey too though. I do however like this whole idea from a technology and relaibilty standpoint.
Old 11-07-2006, 08:37 PM
"Puddles the Pontiac" "Puddles the Pontiac" is offline
Send a message via Yahoo to "Puddles the Pontiac"
i have got a TPI Formula circa '87. they are OK at best. they are fun, but nothing that really gets the heart racing. the engines are nothing more then a standard small block chevy. with an after market intake and a good set of vortec's they wake up alot, but it just doesn't make sense to save a TPI motor and yank the TPI. save the mods for a car already with TPI, if you find just a motor, put it in an s-10. now those make for fun rides.
Old enough to know better, but still too young to care.
Old 11-08-2006, 04:03 PM
fyrebird68's Avatar
Thanks for the insight. I fully agree with ww3 about the LS6. Now I just need to wait until somebody wrecks one!
Regards,
Bob Trimpe
Old 11-08-2006, 06:18 PM
WW3's Avatar
WW3 WW3 is offline
Set up an ebay search notification for 2005,2006 LS2 engine. One will show up eventually. I've loosley searched before and I came up with one on auction about 2 months ago or so. It was a complete LS2 in the K member with transmission and all wiring and ECM. I *think* it was about at $2500 but it was a plug and play 400 horse low mile deal from a totalled '05.
Old 11-08-2006, 08:52 PM
i believe they also come new, as a crate motor. through GMPP
Old 11-09-2006, 05:58 PM
fyrebird68's Avatar
WOW. I can swing $2500.
How do you set up an ebay serach notification?
Old 11-09-2006, 08:12 PM
WW3's Avatar
WW3 WW3 is offline
Well? first I would find the catagory that an LS2 would be listed in ( like this http://motors.listings.ebay.com/Car-...istingItemList ) and then do a manual search for " LS2 ". Then somewhere on that page e-bay asks you if you want to "add to favorites search". Click on it and if you're logged in already it'll put it your "favorite searches folder" in the My E-bay portion of your user I.D.
Then when one comes up you'll get an e-mail(if you've set your preferences that way) from e-bay directing you to that auction.
EDIT: I just did that search and a couple came up....but... a helluva lot more than $2500!!
Be afraid, be very afraid...but they have no bids so that doesn't mean they sell for that money, they're just listed for that money.
Old 11-10-2006, 02:16 PM
WarbirdTA's Avatar
WarbirdTA WarbirdTA is offline
Looks like one set of runners is pretty much dented beyond repair.
I have three sets sitting in my garage.
Just no wireing harness for any of them.
George
