Old 11-13-2006, 10:26 AM
ry57pont's Avatar
ry57pont ry57pont is offline
Default why is this happening, moisture in breathers?
When I took off my valve covers yesterday to check the rockers, i noticed the milky oil in the bottom of the breathers. The motor only has about 500 miles on it. why is this happening? I did put the car away on a cold day do you think it was not warmed up enough?
1970 gto (4spd) 462 500 hp
[email protected] / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 11-13-2006, 10:36 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Condensation. Your last sentence sums it up.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 11-13-2006, 10:42 AM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
are you running Valvaline oil?
8.30 @ 165 mph 3,380 LBS
Old 11-13-2006, 11:01 AM
ry57pont's Avatar
shell rotella 15w-40. This is not a sign of a failed head gasket?
1962 corvette
Old 11-13-2006, 11:09 AM
steve's Avatar
steve steve is offline
my motor did that when i did not have the pcv system set-up right.....
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 11-13-2006, 11:16 AM
scott70's Avatar
scott70 scott70 is offline
Mine does the same thing,even collects in the rubber tube,i clean it all out a couple times a year and far as i know,no engine problems just condensation.
Old 11-13-2006, 11:21 AM
BILL BOWMAN1's Avatar
This happens with short run, short trip cars. You have to get it good and hot for a while to burn it off.
Old 11-13-2006, 11:57 AM
Tim Corcoran's Avatar
In Arizona we don't have a lot of moisture in the air so condensation is not normally a problem. When my breathers looked like that I had a blown head gasket. It could be just condensation but it could be a bad head gasket too.
Tim C
Tim Corcoran
Old 11-13-2006, 12:00 PM
Agree with the burn off of the moisture and also that you need a proper PCV system as the corrosive gases are really bad on the lower engine without a good one working. Engine live went up tremendously one people figured out that they needed to expel the corrosive gases in the crankcase. The road draft tube was the first step in that direction. PCV is a much better step.
Warm up the engine properly for a while and then look for condensation in the covers.
The man is from Minnesota so I would assume the cold weather is contributing.
Old 11-13-2006, 12:50 PM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
"The man is from Minnesota so I would assume the cold weather is contributing"
i even get that all the time on my race car when i open up the valve covers out here in California ! nothing to worry about .
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 11-13-2006, 12:56 PM
Bruce K Bruce K is offline
What would be the best way to run a PCV?
'79 T/A 6.6 4-sp, 3.23 , 463" E-heads, 252/262 hyd roller, TII, Holley 830, 8.384 @ 93.86 - 1/8, 12.5 @ 116 - 1/4, 2.035 60', 3800 lbs. w/o driver
Old 11-13-2006, 01:34 PM
scott70's Avatar
Like i said mine has done it for a while,seemed worse after i put the evac system on ,itsoff the collecters .And it isnt run very long compared to a street car.
Old 11-13-2006, 01:41 PM
coslanzetta's Avatar
coslanzetta coslanzetta is offline
definately condensation, chrome valve covers also are prone to this problem
billet covers are a little better for not having this prob,i wouldnt even worry about it
Old 11-13-2006, 01:43 PM
condensation,chrome valve covers are more prone to causing this,and if you
park the car outside in the weather,instead of a garage,billet valve covers
dont do this as bad,
Old 11-13-2006, 01:58 PM
BVR421's Avatar
BVR421 BVR421 is offline
Do it the way the Pontiac factory did it for 40+ years.
Oddly enough many people remove the factory PCV system thinking its a "smog" device.
It is, but its also an anti sludge device. It only has positives and no negatives.
Old 11-13-2006, 02:28 PM
Use the valley pan, into the carb base?
Old 11-09-2009, 10:14 PM
Banditogto's Avatar
Banditogto Banditogto is offline
Hmmm, older post, but after running my car this weekend, pulled the valve covers just to inspect the rockers, and noticed the oil up top was a little milky looking. Turned the valve covers over, and they had a layer of what resembled white lithium grease. Drained the oil expecting to find water in it, but no water. Moisture is all up top under the valve covers and in the breathers. Ran this same motor back in june, without this problem. Since then, I've only had the intake manifold off. I am using Valvoline oil, and I don't use a PCV valve. What could be causing this now?
Old 11-10-2009, 12:35 AM
BVR421's Avatar
reread all the above posts
