Old 11-14-2006, 11:22 PM
Philcol Philcol is offline
Default Flexplate
What size are the bolts that hold the flexplate to the crank? I need the bolt head size.
Phil
"dreamed I was wide awake........woke up and I was sound asleep"
Old 11-15-2006, 09:50 AM
fellro fellro is offline
Should be 3/4, or 19 mm.
71 Lemans T37- waiting to be worked on...
83 T/A, 305 auto, rear disc
Old 11-15-2006, 03:32 PM
engineer engineer is offline
but not necessarily hex head, some were 12 point heads. hard on sockets since no impact sockets are made that way.
Old 11-15-2006, 05:00 PM
Can't use socket anyway. Have to make a long wrench to get between flexplate and converter to tighten loose flex bolts. Don't want to pull trans till next spring. Just need to start engine to add antifreeze.
Phil
Old 12-11-2006, 02:44 PM
sorry, no easy way to tighten and torque bolts with trans and convertor in car, bolts should have been lock tited in place to begin with.
