Old 01-31-2007, 02:07 AM
Z Code 400 Z Code 400 is offline
Default Headers for BBC in 2nd Gen F-Body:
Who makes the best fitting (No mod) headers for a BBC in a 2nd Generation Firebird???
Car currently has a 455 with nice Hedman Headers and I need to find a set for the 427 Chevrolet that will fit the 4-speed and backdrive linkage without hacing everything up. This is a side project and your advice is appreciated.
Thanks...Robert [email protected]
Old 02-11-2007, 12:30 PM
TA454 TA454 is offline
I am using hooker compitition headers. The ones for a chevelle work if you are using smaller diameter tubes. The super comp conversion headers are 2" primarys. the standard comps are 1 5/8 primarys. the smaller ones work fine up to @6800 rpm then the motor will run out of power.
Old 02-11-2007, 01:18 PM
tempest455's Avatar
tempest455 tempest455 is offline
I would think and major brand (Hooker, Hedman etc) makes a decent fitting set. Just order for a Camaro chassis.
Tempest455
Old 02-11-2007, 01:47 PM
They do and the fit is basically the same. When i put mine together i got the headers second hand. So in my case a few bucks saved for a new set of second hand headers was still a few extra dollars in my pocket.
Old 12-09-2007, 06:16 PM
What about clearance for the 4 speed backdrive linkage????
