Old 01-17-2007, 08:01 PM
Johnny GTO's Avatar
Johnny GTO Johnny GTO is offline
Default 68-72 trunk panels
I just bought a three piece trunk panel kit for my 68 gto. The parts sticker says 68-72 a-Body. There are some sections that are different than my original. Is this common for reproduction trunk panels?
Old 01-17-2007, 11:13 PM
GStage1's Avatar
GStage1 GStage1 is offline
Minor variance is common.....most likely you have a Chevelle trunk pan kit.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 01-18-2007, 07:58 PM
CraigGT37's Avatar
CraigGT37 CraigGT37 is offline
I bought a kit for my 71 and the ribs on the floor at the tailpanel are different I modified them to fit and look correct.
Craig
Old 01-23-2007, 11:56 AM
PrimeredPontiac's Avatar
PrimeredPontiac PrimeredPontiac is offline
Craig
i had to do the same when replacing the outer 3rds of the trunk floor in my 70 GP
Old 01-24-2007, 12:53 AM
Johnny GTO's Avatar
I am cutting out the old floor tommorrow. I never did this before. I'm a little nervous about it.
Old 01-24-2007, 09:54 AM
GStage1's Avatar
Read my article on our site to get an idea what is required:
http://www.buickperformance.com/TrunkPan.htm
If you need more help, let me know.
George Nenadovich
Old 01-24-2007, 08:17 PM
Johnny GTO's Avatar
Thanks GStage1,
That is one informative page that you made. I noticed that you did this with the frame out. I was told by a few guys that it is better to do with the body on the frame so the new panels will sit square. I lowered the body back down on the frame last Friday. I started to get ready to cut the spot welds only to find that the frame is in the way. Would you suggest putting the car back up in the air?
Old 01-24-2007, 08:31 PM
GStage1's Avatar
I do the metal work with the frame out of the way since it is easier to weld in the trunk braces.
If your braces are good, you can do the pan while the body is on the frame.
I never had a problem installing the pans w/o frame since the body is supported properly.
You can drill out all the spot welds from inside the trunk. I don't know where the frame is in the way in your application.
George Nenadovich
Old 01-24-2007, 11:01 PM
Johnny GTO's Avatar
Thanks, That would be alot easier than bolting it back on the frame, plus alot easier to weld if the frame is out of the way.
Old 02-02-2007, 08:25 PM
Johnny GTO's Avatar
GStage1, How does it look? I tried duplicating yours.
ID:	81399   Click image for larger version
ID:	81400   Click image for larger version
ID:	81401   Click image for larger version
Old 02-03-2007, 01:37 PM
Matador-IV's Avatar
Matador-IV Matador-IV is offline
Looks really good....surprised your trunk rusted out while the braces look so good.
What kind/brand of bit did you use to drill the spot welds out?
The 2 spot weld bits I bought were junk....I think $13.00 each.
Old 02-03-2007, 06:37 PM
Johnny GTO's Avatar
The brand is Blair. It cost $16.00 for the main bit. I bought replacement cutters for $16.00 for a 3 pack. I blew 6 edges out doing the trunk. I kept losing the spring loaded center pin every 2nd or 3rd hole. That kept ticking me off. Its like trying to find a needle in a haystack.
Old 02-03-2007, 06:44 PM
Johnny GTO's Avatar
I just got a doner trunk panel from a 70 Skylark today that is in real nice shape. I may take back the new 3 piece that I bought in favor of it. I can't believe the slight differences between the gto, chevelle and the skylark.
Old 02-03-2007, 11:52 PM
md1twal3 md1twal3 is offline
Well, except the expense, I am glad to see that I am not the only one that tears up spot weld bits! I ended up going to a cheap step bit from harbor freight. Has worked awesome!
BTW....I would use the donor pan too. a bit less work and original factory metal vs. aftermarket is always a plus!
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi
Old 02-04-2007, 06:42 PM
GStage1's Avatar
Looks great! Nice clean metal!
I tried to use the spot-weld drill bit with little success.
I use the titanium-nitride (gold color) bullet-tip dril from Home Depot and it works great...I believe it is 5/16"
George Nenadovich
