I'm trying to find a Bellhousing runout fixture to set up the runout on a new Mcleod scattershield. I have a magnetic based fixture, but it keeps falling off as I turn the engine over. Tavia used to make one p/n 08410, but it is no longer produced. Anyone know where I can get one.
I don't know if there's such a thing available- maybe. I always just rig up whatever little brackets I need to clamp under a flywheel flange bolt and hold a small 'test indicator'- the lever-type indicator, as opposed to a plunger-type. The whole indicator is only about 3" long.
Ok thanks, I just ordered a Tremec 5 spd and in the instructions they require this check to be performed or their warrenty is void. Either a lot of tranny's are installed on blind faith or their has to be a a fixture to simplify this process. Perhaps I need a better magnetic fixture as mine keeps moving around so that I'm not getting an accurate reading.
RAIV55, how about some pics of that thing?
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine" 1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Dual Camaro Fans, Tremec TKO 600, 3.91 12-Bolt Posi w/Bearing Retainers, Complete Frame-off, Boxed Frame, 4X Discs with Hydro-boost and Volvo Pump, EPAS Conversion |
http://www.precisionmeasure.com/fixt5.htm
http://www.advancedclutches.com/prod...t%20Tool%20Kit (may be able to adapt, flywheel/pressure plate bolt patterns are generic on GM) Check Proform, Coleman Racing, Northern Tool, and believe it or not, dare I say, Rock & Roll has one too. You can use a dial indicator and a clutch aligment tool too to do the check, though may not be as accurate...
Sounds like maybe you need a better magnetic base. The one I have wouldn't fall off. The magnet in it is strong enough that it's hard to pull the base off of a good, flat surface. Danged if I can remember where I bought it though...
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
I had no problem with the cheapo base with the dial.
The base and indicator cost $25.00 at a swap meet. I think ENCO even has them for less.
So then I said to myself "what would I do if I was me" ... |
