Old 01-28-2007, 08:58 PM
josh josh is offline
Default Anyone paint their stock floor pans?
Well in the spring im ripping up the carpet and replacing it, and fiqured why its bare why not sand/prime/paint the floor pans? Has anyone done this before? How did you do it, i noticed alot of factory body sealer on both floor pans.
Anyone got pics?
Old 02-06-2007, 02:37 PM
65gofast 65gofast is offline
Default painting floor pans
I have a rust bucket 78 bird that was given to me free 4 years ago. I had to weld in new metal into the floor in several places. Once that was done I painted both surfaces with POR 15. gloss black. It is now solid and strong.
Old 02-06-2007, 03:19 PM
I ended up buying POR-15 the floorpan resto kit a week ago. How do you like the results of the POR-15? The directions make it seem its very unstable.
Old 02-06-2007, 03:48 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
I painted the floors on my GTO with POR-15 a few years ago and then just last month painted the floors on my Formula with Eastwood's Rust Encapsulator in red oxide. Both went on really well. I scraped up all the carpet underlayment/deadener and then wire wheeled the floor to clean and rough it up a little before painting. You can paint around the seam sealer or cover it if you like, I believe both paints will cover it. Kind of hard to say if any of it ever came up since it's under the new deadener and carpet but I seriously doubt either of those floor pans will ever rust! Here's a pic of the front driver floor. I think the color comes pretty close to the factory red oxide.
Name:	Formula floor.JPG
Old 02-06-2007, 04:13 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Before
After
POR-15
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 02-07-2007, 10:32 PM
Default POR 15
I have used POR15 for yearsand it works very well-good stuff, I never have had ant recuring rust.
Old 02-08-2007, 12:21 AM
1Bad78zam 1Bad78zam is offline
I rolled in bed liner on my floors. Cut down the road noise!
Black 78 T/A - high school dream car
69 Bird LS swapped
White 00 WS6 T/A
