Old 02-15-2007, 02:26 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Default 800HP D Port
The latest dyno results of my 469 cid engine are in. We were able to make a little over 800 naturally aspirated HP with my self imposed limits of OEM block, OEM crank and OEM D port head. It made 806 HP at 6700 and 695 lbs ft Torque at 5100. Volumetric efficiency peaked at a very nice 127.1%.
1969 428 Block; 4.190” bore; Filled to bottom of freeze plugs; 3 center billet caps
9799103 “N” 455 crank stroked to 4.250”; Radiused counterweights to reduce windage
6.782” connecting rod
JE flat top pistons
Child and Albert gapless rings
#48 heads; substantial port work; flowed over 315 cfm with intake and carb; much epoxy
2.110”/1.770” REV custom valves
13:1 compression
Isky Solid roller cam; approx 270/280 at .050”; installed at 105 IC
1.65 Crane gold roller rockers
Manton 9.400” pushrods
Victor intake welded and heavily ported; polished exterior; 1” spacer
1050 Dominator; tweaked
MSD billet distributor; crank trigger
2” Hedman Hustler headers; 30” collector extension
Star Vacuum pump
Custom built oil pan
Best power was made with 32 degrees timing, 10” vacuum pump setting, 88 jets, 145 water temp and 130 oil temp.
Built a sheetmetal intake for this combination but it was down on HP and torque slightly from the Victor, long story but I wanted to run the shaker on my 71 TA so some compromises were made in the initial design. We are still working on making this intake work in the car.
Best of luck to each of you in 2007,
Jim Robertson
Robertson Auto Consulting and Engineering
www.racev8s.com
Old 02-15-2007, 02:32 AM
Old Man Taylor's Avatar
WOW!
Old 02-15-2007, 03:49 AM
R 70 Judge's Avatar
Originally Posted by Old Man Taylor
WOW!
Exactly! That is incredible!
James
1970 Trans Am
Old 02-15-2007, 07:23 AM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Impressive for a stock block/crank deal!! Any worries with those parts?
Old 02-15-2007, 08:54 AM
Tim Corcoran's Avatar
Jim,
That's very impressive power for a relatively small cube D-port motor. What kind of flow numbers were you getting on those 48's on the exhaust side?
Tim C
Tim Corcoran
Old 02-15-2007, 08:58 AM
tempest455's Avatar
tempest455 tempest455 is offline
Obviously, this was not his first time at the rodeo!
Tempest455
Old 02-15-2007, 09:01 AM
Larry Navarro's Avatar
For those who haven't looked.......click on Mr. Robertsons web link.
VERY impressive and informative site.
The fabrication and craftsmanship is incredible.
Old 02-15-2007, 09:17 AM
BILL BOWMAN1's Avatar
Old 02-15-2007, 09:27 AM
Helluvadriver Helluvadriver is offline
Thumbs up
I thought 300cfm d-ports was a myth but these pics make me think otherwise.
Old 02-15-2007, 09:39 AM
Thanks for the kind words. It was a project that I let drag on for three years. The heads took the longest to get them to do what I had envisioned.
Exhaust went 206 cfm @ .700" lift @28" on our bench with the 2" car header attached.
Jim
Old 02-15-2007, 09:43 AM
BigB's Avatar
BigB BigB is offline
Very Nice!
Old 02-15-2007, 10:31 AM
johnta1 johnta1 is online now
Fantastic Job!
What's it going in?
Old 02-15-2007, 10:45 AM
Region Warrior's Avatar
Very impressive.
Didnt even have to go over 7K.
Old 02-15-2007, 10:48 AM
slowbird's Avatar
slowbird slowbird is offline
gas or alcohol
Old 02-15-2007, 10:51 AM
uneasyrider's Avatar
uneasyrider uneasyrider is offline
FAR OUT!
Uneasyrider
“To find yourself, think for yourself.”
― Socrates
“The unexamined life is not worth living.”
― Socrates
“Wise men speak because they have something to say; fools because they have to say something.”
― Plato
Old 02-15-2007, 10:55 AM
I'll bet those aren't 160cc D ports either! They look huge! And not a low rpm D port motor either.
Neat project good luck with it!
Old 02-15-2007, 10:57 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Outstanding accomplishment.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 02-15-2007, 11:08 AM
fasteddy's Avatar
fasteddy fasteddy is offline
Jim, I am jealous. What a great D-port accomplishment-in fact that would be impressive with aluminum round ports. (Jim is a really nice guy too) cigars were good. LOL
fasteddy
Old 02-15-2007, 11:13 AM
.......think i'll throw my d-ports out the window.....
Old 02-15-2007, 11:25 AM
Originally Posted by BILL BOWMAN1
Great signature!
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
