Old 03-05-2007, 08:42 PM
captain42082's Avatar
captain42082 captain42082 is offline
Question question on 6x heads
6x-4 head on the driver side between the #1&#3 spark plugs,beneath the n/d casting mark there is a threaded? plug in the head with what looks like a vacuum fitting on it . what is this,there seems to be no vac at the fitting! should it be taken out of the head and blocked off,or anything. what is the purpose of it?(drivers side head) thanks If I am not worrying about something,i will find somethin-LOL
Old 03-05-2007, 08:51 PM
66bonne's Avatar
66bonne 66bonne is offline
I'd bet you are looking at the provision to mount a water temp sensor in the head. I don't know why it would have a vacuum fitting on the plug, sounds like someone put that in because it fit. I would just plug the hole and forget about it.
Old 03-05-2007, 09:20 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
It`s an old EGR thermo-vacumn switch or TVS. It kept the EGR from operating till the water temp. got to the specified temp. It`s not gonna hurt anything unless you think it`s ugly. Then i`d use a pipe plug.
Old 03-05-2007, 09:39 PM
tom bryner tom bryner is offline
Another 6x head question. I have a 72 455 with 6x heads, how can I tell what year these heads are? My car is a 73 formula. Thanks.
Yellow73
Old 03-05-2007, 10:58 PM
thanks for replys,yep,just kinda sticks out there,not really ugly like me! should be numbers on the heads to id what year
Old 03-06-2007, 12:11 AM
Lightbulb
There should be a date code, cast into the head near the valve cover like 'A226' (Jan. 22, 1976).
Old 03-06-2007, 01:11 AM
Tim Corcoran's Avatar
did somebody say hijack?
Tim Corcoran
Old 03-06-2007, 02:14 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
.... Seeing as how somebody said "Hi, Jack!", I might as well respond with a dumb question-
In the example above, how do I know that's not January 22nd 1966?
Old 03-06-2007, 01:24 PM
Cool
Anyone with a little bit of Pontiac engine knowledge knows that 6X heads were a late-'70s casting, right Jack?
All it takes is $20 spent on Pete McCarthy's book to know pretty much all about Pontiac head ID.
Oh, Hi Jack!
Old 03-07-2007, 02:08 AM
Originally Posted by b-man
Anyone with a little bit of Pontiac engine knowledge ...
Well, you got that right- I've only got a little bit of Pontiac knowledge. Never got around to reading the '70s parts of Pete's book.
But what about the substance of my question- are some Pontiac date codes redundant between decades?
Old 03-07-2007, 10:54 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Yes they are. I have a 1965 389 head that has a date code of D215 and a 1975 6X head that has a date code of D145.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 03-08-2007, 01:55 AM
Thank you.
