Old 03-21-2007, 10:06 AM
60man's Avatar
60man 60man is offline
Default Ready for dyno..Hot Damn...
Just to throw my hat in the ring...
Picked up motor a couple of weeks ago from Jack Gaydosh..had to swap out some parts to get it ready for dyno..
My thanks and kudu's to Jack, he's always first class at whatever he does..
Without his help I wouldn't have this motor..
My thanks to Brad Wallace (Wallace Engine Co.) for his machine work,friendship, and input to
New intake,headers, CSR pump, & dist. still on old motor..
Want to try out some stuff before switching to new bullet..
Hope to play with it at VMP...
All Pontiac.com IAII block
Crower billet 4.250 crank
BBC Eagle rods
Ross pistons & pins
Custom ground Chet Herbert solid roller cam
KRE D ports ..325 CFM set up for solid roller
Cometic head gaskets
Harland Sharp 1.5 rockers(for now)
Jomar rocker stud girdle
Bearing cam retainer plate ( Scott's) with billet timing chain set up
Power Bond SFI damper
Canton oil pan
TCI flex plate
Sorry no Stelka or fabed valve covers.
Need "Old School" look for NSS classes...
Old M/T covers will be back on after dyno...
Name:	IMG_1246 (Small).JPG
ID:	86015   Click image for larger version
Name:	IMG_1242 (Small).JPG
ID:	86016   Click image for larger version
Name:	IMG_1244 (Small).JPG
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 03-21-2007, 10:12 AM
Nice motor!! How tall are those ports? My KRE CNC E heads are 2.400 tall.
Looking good.
When's it going on the dyno?
Old 03-21-2007, 02:18 PM
60man's Avatar
Ditto on ports Skip..
How wide are your ports ??
ECM member.
MANDRA
Old 03-21-2007, 02:26 PM
60man's Avatar
Originally Posted by johnta1
Looking good.
Thanks John.
Shooting for 2nd or 3rd week in April....
Jack will be there so I'm working along with him...
This will be the first motor I have ever had dynoed !!!
No hurry...trying to do it "right the first time"...
Thanks again to Jack.
John ....I take it you are a Wallace. Are you related by chance to Brad Wallace ?...Essex,MD.
ECM member.
MANDRA
Old 03-21-2007, 02:36 PM
Not that I know of.
Sounds like a smart guy though!
Old 03-21-2007, 04:20 PM
I forgot the actual width, and it has an intake bolted. I want to think they are the same width as the big SCE gasket that is 2.350 tall. I'd bet they would use the same dimensions. That's why the T2 and Tomahawk needed a little extra up top to seal.
Sounds like that motor is a little too big to blow out some long branches, even those big early SD types
Old 03-21-2007, 07:13 PM
60man's Avatar
What long branches ???
Tri-Y's are also gone and trying to adapt some 2" Husler headers...
will probably wind up with custom made set....$$$$
At any rate I have modified a Hooker Super comp set 1&3/4 for now,
from a 68 GTO....
I had to weld up my Offie intake to get the height to match up !!!
No problem with the Wenzler....
ECM member.
MANDRA
Old 03-21-2007, 07:35 PM
Steve C. Steve C. is offline
Bore size and cam specs ?
Old 03-21-2007, 08:20 PM
60man's Avatar
4.350 bore....
284/288 @ .050..108 LCA---.750/.690 gross lift-1.65 rockers...
Now I'll probably be assinated....
I can't wait for dyno results..
I have a gustimate....but I'll wait....
ECM member.
MANDRA
Old 03-21-2007, 08:48 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Real nice, can't wait for some numbers.
Maybe measure it with a USA ruler - might measure different.
Old 03-21-2007, 09:13 PM
60man's Avatar
Whoops...sorry about rice ruler...
I curious about some numbers to..
I want to play around with rockers on both exhaust and intake..
I have a Desk top Dyno figure I want to see on dyno..
GTO Geoff will love this...he knows what I mean...I'm sure..
ECM member.
MANDRA
Old 03-22-2007, 06:18 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Damn, you really stepped things up a "notch", can't wait for the dyno numbers! I love seeing what these "little" "D" port heads can do!......Cliff
PS: I hope you've got good brakes on that old car, gonna be interesting trying to stop 2 tons at 130mph!!!
Old 03-22-2007, 08:10 AM
quick67bird's Avatar
quick67bird quick67bird is offline
Troy,
How wide are your ports. My Kre dports are the 340 cfm version and they look to be the same height as yours. I have to get a measurement of my heads width.
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 03-22-2007, 08:35 AM
10second70GP's Avatar
10second70GP 10second70GP is offline
REALLY NICE 60 MAN CANT WAIT TO SEE #S
Old 03-22-2007, 08:52 AM
65gto69's Avatar
65gto69 65gto69 is offline
Hey Troy,
Motor looks great, That Jack can really put a motor together.
I can't wait to see those numbers also.
Good luck with the new mill, hope to see it run this year.
Mark
P.S. If that motor turns out to be tooooo much for you, I will trade you my Jack motor for yours
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 03-22-2007, 08:57 AM
Chris Roach's Avatar
Chris Roach Chris Roach is offline
Sheesh, those casters on that engine dolly look like they're ready to bite it!
Nice motor by the way!
1969 GTO Judge Ram Air III
1968 Catalina "Darkside" Vert!
Old 03-22-2007, 05:03 PM
White Warrior White Warrior is offline
Nice combo Troy, Hope your chassis can hold it. Dave Johnson
Old 03-23-2007, 03:20 PM
60man's Avatar
Hey Cliff. I can't wait to see what these poor old "little" D ports do either.
Hopefuly enough to Keep on truckin'...
Got to keep these Ventura's rockin'
I hate to part with 8 lugs but I also have a Scarebird front disc conversion setting on the shelf. It's not the 1/4 mile tracks that get me...it's those short little 1/8 mile tracks with even shorter shut downs... Have had to change shorts all ready a few times....
Quick67: I think port width is 1.50 or 1.55.
I really don't know the port cc's....Just haven't bothered..
I'm with you 10second70GP..####'s please
Hee-hee..thanks Mark..think 60 will be fine with 505..
Chris:..Yep the casters are "Roached"....
Dave...I've made a few "small" changes to suspension and beefed drive train. Hope it will hold until I figure what I want to do.. Maybe at least you won't blow my butt away to bad at Norwalk...
Steve C.- Just barely made it back from Tenn. without being assignated..
ECM member.
MANDRA
Old 03-23-2007, 04:21 PM
Reportably the KRE 325 cfm D-ports have about 215-220 cc intake runner volume. With that big cam it will be interesting to see where the motor makes it's peak power at. Any hints from the computer program ?
With a shorter 4.125 stroke the 482 using the Edelbrock heads at a 234 cc runner volume made its peak power at 6900 rpm with a 279 at .050/.704 lift solid roller. With the new revised combo and using the bigger High-Port heads John's motor made it's peak power at a lower 7000/7100 rpm with a 285 at .050 /.850 lift roller.
(I'm trying to keep my new street 505 under 6000 rpm. Should dyno next week)
